what prop?
  • motohead417
    • 92
    what prop?
    hey guys i have a ammo 2300 that i wana put in my blackjack but i dont know what would b e a good prop for that motor. what prop should i go with a x442, x440 or you guys suggest somthin else?
  • Tony
    • 420
    I don't know too much about ammo 2300, but i am running x642 prop with an original ProBoat motor that was installed by the manufacture w/o any issues. So, if the ammo 2300 is better than the OEM motor. I don't see you having problem with x440 or x442 prop.
    • NorthernBoater
      • 869
      I would start with an X440 and if that if temps are good try the X442. I have always been a fan of the M series props.
      • 785boats
        Wet Track Racing
        • 3423
        The Grim Racer 40mm X 52mm 3 blade is a good one. Lets that motor rev, which is what they like.
        If the boat runs fine on the X440 with no heat problems (& there shouldn't be if the hull is running nice & dry) try the X640.
        As Northern Boater suggests the M series props would work well. The M640 or maybe the M642 would be good. I've not tried them myself so I can't tell from personal experience.
        As always start with the smallest, in both diameter & pitch, & work your way up.
        Cheers.
        Paul.
        • properchopper
          rcgoatbuild@snotmail.com
          • 7708
          Cheers.
          Paul.
          the Octura 640 & 642 are "x" props. Good props but watch heat; I've toasted my Ammo on a tunnel with smaller props.
          • motohead417
            • 92
            i currently have a x642 on the boat and i am not happy with the performance. i got better speeds with the stock motor than with the ammo 2300. i am jus looking to get as much speed as i can out of the ammo.
            • NorthernBoater
              • 869
              That would indicate the x642 was loading down the motor to much and not letting it rev up. You either would need to go to a lower pitch or smaller diameter.
              • domwilson
                • 4411
                Look at post #16 to see how his strut is adjusted. He broke 50 with his setup.
                http://forums.offshoreelectrics.com/...ead.php?t=2200
                __________________
                Government Moto:
