ABC Hobby Fighter 550
  • mike a.
    • 86
    i had the kyosho sunstorm which held the batteries down the same way. It used velcro on the two ends of the battery, it worked pretty good
    • saleens7
      • 1130
      i dont have velcro....although i did have epoxy and zip ties as you can see in the pic:D
      saleens7, the wookie of rc boating
      • mike a.
        • 86
        can you still take the batteries out to charge them or do they have to stay in the boat to charge them?
        • saleens7
          • 1130
          stay in the boat....but thats fine...
          • Jeepers
            • May 2007
            • 2050
            Go to your local "WALMART" or what ever you have there, and in the sewing section you can get like 5ft of the industrial stick stuff for about 6$
            Uggh I HATE THAT STORE! Seriously!
            • saleens7
              • 1130
              a bit too late....plus i want to run it tomorrow and my parents arent going to to take me to wal-mart....or any other type of mart for that matter...
              • Jeepers
                • May 2007
                • 2050
                DUDE your about to get FLAMED on this one!!!!!!:D
                hope your firesuit is READY!:p
                • saleens7
                  • 1130
                  actually, i think i can slide one off and slide the batt out of the other one....i give it a try...
                  • Jeepers
                    • May 2007
                    • 2050
                    I just know alot of people really dislike that idea! especially on lipos.
                    • saleens7
                      • 1130
                      but this is nimh and ive charged these batts before many times (in the boat and out of it) with no problems...
                      • Jeepers
                        • May 2007
                        • 2050
                        I know, so have I! I just remember someone getting "jumped" on for saying that. thats all
                        • Rex R
                          • 1007
                          ah now I see how they go(cell pack), thanks for the pic. on your 'to buy list' put down velcro. seriously you'll be wanting it for ALL your boats it is just so handy. I've used it to mount rx, batts, and esc's. while your solution will work...it does rather limit the amount of run time for the boat(no. of runs per day).
                          • saleens7
                            • 1130
                            eh, doesent really matter to me too much....my charger has a 4 amp charge rate, that charges the batts in less than an hour...besides, i dont like to charge packs when im not home, i like to play it safe...
                            • saleens7
                              • 1130
                              i finally got the boat to stop bouncing...the batt is further forward, so it balances the boat better and stops the bouncing...but now large amounts of water keep coming in the boat....and i dont even know where...the hatch was taped shut, the stuffing tube was siliconed where it met the transom to seal the hull.....what i dont like is how the stuffing tube is like 10mm and it only uses a 4mm shaft and all it uses to seal it these two littke bushings like 4mm long that "seal up the end of the shaft,,,only problem is that they arent glued in place, so they come loose during the run and besides letting the shaft vibrate, im guessing its where the water is coming in....i also tried the yellow prop and there was no gain in speed, im going back to the stock one..
