TS2 conversions?
  • NorthernBoater
    • 869
    TS2 conversions?
    How have people built up the battery and ESC box on the TS2. I am curious how others have done it before I start.
    Andy
  • eboat
    • 726
    Just started cutting till it fit
    • NorthernBoater
      • 869
      Did you use balsa or plywood?
      • eboat
        • 726
        I used plywood balsa is to soft
        you could use the balsa to make the pattern of the side of the box (trial and error)
        I just used cardboard to make my pattern with
        • Diegoboy
          • Mar 2007
          • 7444
          Here's a good build thread.
          • properchopper
            rcgoatbuild@snotmail.com
            • 7708
            TS-2 Build
            Here's how I did my box. Most I've seen put the servo in front; I like mine in back to simplify linkage. Also, I made mounts for the box so that it's easily removeable and transfers perfectly between my 2 TS-2 hulls. [ Pix spread over successive posts]
            Tony
            • properchopper
              • 7708
              more pix
              transferrable mounting detail
              • properchopper
                • 7708
                But Wait !!
                I just remembered this !
                Laser Cut USA
                612 SW Biltmore St.
                Port St. Lucie, FL 34983
                1-772-528-4727
                pjf610@Yahoo.com
                Laser cut radio box kit for the TS-2 !!!
                • properchopper
                  • 7708
                  My little friend !
                  Andy, do seriously consider one of these little gems : IIRC @ $ 110 bucks at Home Depot & worth every penny, indespensible when building boxes from scratch. [Ask Darin !]
                  • NorthernBoater
                    • 869
                    Tony
                    Who makes the orange mount you are using for the REK lower unit?
                    • properchopper
                      • 7708
                      Victor Gorecki [ Capt'n Vic]
                      Vic_spm@spcglobal.net
                      He just made some new ones in several color choices
                      For some reason, the post underlined the whole link; only one underline between Vic and SPM
