zippy lipos thread
  • crabstick
    • 955
    zippy lipos thread
    Hi Guys
    Have noticed a few people mentioning that Zippy Lipos may not be up to the job, Just wondering if anyone has any Data on this ? like back to back tests with other cells ?
    Graphs amps vs volts etc ?
    Its easy to parrot what other people say and assume they are not up to the job, but has anyone done any actual testing?
    Matt.
    www.rcboats.co.nz
  • LiPo Power
    DJI Drone Advanced Pilot
    • 3678
    I am using zippy lipos on Formula Fastech, BJ and UL-1, works like a charm. Have no data for you but just like to say my 3 words to your quastion. Ooo, Doby is using them and he is happy also.
    Canada
    • DISAR
      • 1137
      About amps I don't know, but the quality is not good. I had one that got wet and the positive tab broke-erroded after a day and cannot solder it. In two others one cell just died and don't know how. I would suggest Rhino (so far so good) and then the famous ones (Flightpower,polyquest etc...).
      http://www.rcfastboats.com/
      • crabstick
        • 955
        if you got it wet its possible it shorted out and corroded that tab, I had the same happen. No lipos should get wet IMO.
        I am more interested in AMP draw capabilities.
        I have had good results to date, 53mph on 4500mah 25c zippys on 8xl powered cat (oval setup)
        I won our recent club champs for P-Restricted (4s 2pole motor, max 6000mah) with Zippy Flightmax 30-40c 2650mah 4s2p to give me 5300mah. I was the only one in the class running Zippys, everyone else running Enerlands of some description.
        So I know they work, just After some real DATA if possible
        Matt.
        www.rcboats.co.nz
        • Flying Scotsman
          Fast Electric Adict!
          • 5195
          You get what you pay for. Where is the proof of 30C
          Douggie
          • 6S HYDRO
            • 1325
            the rhino's have been super strong for me, also ive found the zippy cells are pretty safe- i had a puncture in the end of one of my flightmax 3s 4000's and nothing happened- i put some epoxy over the hole (and no chemical fire) then charged it up and it has been working fine since. one of my thunderpowers got punctured and what a fire that was and the only fire experience ive ever had with lipos in my 3 years experience with them
            • ghostofpf1
              • 399
              You need special aluminum flux paste to solder the aluminum tabs...
              Steve
              • Flying Scotsman
                • 5195
                I am not talking about safety the C rating is my question...Zippy prove it under boat demands
                Douggie
                • crabstick
                  • 955
                  Douggie
                  AHA ! Exactly ? Someone must have some DATA.
                  One would assume so, But I have been stung in the past by assuming this.. IE Buying thunderpower and thunder power packs for my heli... assuming because they were expensive they must be good, they flew the same as my zippy packs after 2 years the thunder power and align packs dont even hold a charge, the zippy packs I can still fly.
                  I did hear a rumor that the some Zippys were enerland rejects.. but as I have seen no data one an only assume, and assumption is the mother of all " F#$Kups "
                  Matt.
                  www.rcboats.co.nz
                  • 6S HYDRO
                    • 1325
                    jeez man, i thought id post my experience w/ them since this is a zippy specific post.
                    all my batts pretty much are all zippy and theyve been holding up to boats flawlessly
                    • crabstick
                      • 955
                      all good, keen to hear reports good or bad..
                      Matt.
                      www.rcboats.co.nz
                      • 6S HYDRO
                        • 1325
                        i was talking to the scottsman
                        • Brod
                          • 196
                          All my ten packs running fine,all closely balanced.
                          These Zippys seem underrated in mah too,a 5000 can give almost full capacity before obvious voltage drop.
                          I haven't done more than about 12 discharges with each set yet,so maybe time will tell if they are REAL good cells.
                          One pack was taken out by an Esc which basically was my fault,over propping a fast setup even more,tabs were burned,i can easily fix it.
                          Soldering is as good as many of my Enerland packs.
                          Its the price i like the most.
                          Brod..
                          Slow gets boring fast.
                            • 9481
                            This is good info...
                            • Ub Hauled
                              • 3051
                              Originally posted by 6S HYDRO View Post
                              .......i put some epoxy over the hole (and no chemical fire) then charged it up and it has been working fine since.
