x640 or x442 prop
  • vvviivvv
    • 1148
    x640 or x442 prop
    feiago 8xl 4s in a 60cm cat
    which prop + speeds on each of them?
    thanks.
    Uk SAW record holder
  • Flying Scotsman
    Fast Electric Adict!
    • 5195
    That is a lot of motor for a 24" cat...what hull....what batteries...what ESC. what run times??? Your suggested props are way too large
    Douggie
    • vvviivvv
      • 1148
      4s2p zippy's 2650mah each 30c<-
      AS26-150bl esc
      drifter s hydro marine
      • Flying Scotsman
        • 5195
        You are running 2 4S2P in parallel ?
        Have you bought the motor?
        Is this your first boat?
        Douggie
        • vvviivvv
          • 1148
          2p as in 2650+2650 5300 total and no its not my 1st have the motor from annother project
          • Flying Scotsman
            • 5195
            The motor is way overkill and what run times. The ESC I am not familiar with is it a car/aeroplane design
            • properchopper
              rcgoatbuild@snotmail.com
              • 7708
              I've run my Drifter S with an 8XL / Hydra 240 and a X642 for over a year on 4S 2P
              4100 30C Neu batt's. Close [ 59.1 GPS] to 60 MPH. Watch temps after 2-3 minutes. Highly entertaining turns, er, barrel rolls at speed
              • Flying Scotsman
                • 5195
                Tony, you are the man. I was just trying to caution this dude on his setup
                Douggie
                • vvviivvv
                  • 1148
                  i was present at my uncle barrelrolling his hpr135 up the shore after spending 1000's of £ building it im not gonna make the same mistake im building the hpr06 atm this is a quick build for now
                  • vvviivvv
                    • 1148
                    so x640 over 442?
                    • properchopper
                      • 7708
                      Try both. Tape up good & use lots of flotation !
                      • vvviivvv
                        • 1148
                        foam inserts around the hatch shaft is perfectly water-tight + hatch tape
                        • properchopper
                          • 7708
                          I'd pin the front of the hatch. If you're looking for high speeds, you may suck the hatch off in a flip, taped or not. I sucked a hamburger-sized patch of gelcoat off the hatch at a race at Kaiser Cove ; the hatch would've come off without the pin [ a small rivet]. All my hatches are now pinned or otherwise secured.
                          • vvviivvv
                            • 1148
                            ill think something up tomorrow along them lines
                            • properchopper
                              • 7708
                              Here's another easy hatch-securing technique : a garage door opener belt-clip epoxied to my DF 33 hatch. The dark area on the hatch is the repair to the same gelcoat-ripping event that happened to the Drifter. Saved the boat, for sure ! [Water gets hard and abrasive at high speeds, trust me !]
