Originally posted by MonsterMaxx
View Post
First of all I hate to be blunt, but the banner add, the forum post and the contact page of OSE "ALL" say that I'm closed for vacation. BUT I have still responsed to your email while on vacation. Not sure what else you want from me? Here it is the email and the time stamp.
Sent: Thursday, July 09, 2009 10:39 AM
To: 'Robin'
Subject: RE: OffShore Electrics Inquiry
Hi Steven, since you were closed and I couldn’t find anyplace to get the items needed to finish the Titan 27” for 6s like we discussed I managed to find a used UL1 to play with for the weekend.
I sent you this message Sunday via your store’s contact form, but it seems you didn’t get it.Links get picked up by spam and kicked out sometimes.
Now I have two boats to hop up J
To recap, these will both be powered by 6s30c2650 packs (440g ea) wired parallel. I have checked, they do physically fit both boats.
I would like to take them as far as I can right out of the gate including upgrading the ul1 to a .187 shaft. The Titan already has a .187 in it.
I’d like a nice selection of props too. Up to $100 worth. After shattering the UL1’s stock prop I’m not wild about plastic, but I suppose for tuning the carbon ones would be ok. If I could get one polished and sharpened one that you think will be the best guess, I’ll polish the rest of the bare ones myself.
So, if you could do a sanity check on the items I’ve selected make sure these will work for what I’m trying to do. Also, if I’m missing anything I’ll need, like a .187 collet for the ul1 which I can already see I’ve missed.
And my last request is if you could offer a discount I’d sure appreciate it. Perhaps a “20% the economy is in the crapper” discount? J
Sure would be great and I could place the order asap.
Anyway, below is a list of items
Thanks,
Robin
Details Name Unit Price Quantity Total Select
AquaCraft Vertical Fins RED UL-1 Superior $20.99 1$20.99 [ ]Fin Color: - Red Fins pn#aqub9302- -
These are stock fins. Same as you have on the UL-1
AquaCraft Hydro Turn Fin CNC Black Anodized $20.99 1$20.99 [ ]
This is the stock fin on the Ul-1. It will not work on a titan.
Feigao 540XL "Extra Long" Sized Brushless Motor $69.99 2$139.98 [ ]feigao 540XL: - 540 13XL 1,339 RPM / Volt- -
This is a good motor for 6s. It will draw 50-70 amps at its efficiency range. Prop to draw about 50 amps and make sure your esc and batteries will handle it.
OSE Black XL Water Jacket for Feigao 540 XL & L Sized Motors $16.99 2$33.98 [ ]
This will work with that 540 feigao motor you picked.
Octura Brass Bullet Nut for 3/16" shaft $2.99 2$5.98 [ ]
This will work with a Octura and hughey 3/16” shaft with 10/32 threads. Not the ul-1
Octura Large Drive Dog for 3/16" Prop Shafts $2.99 1$2.99 [ ]
I would use the small drive dog. It gives you the ability to use the smaller hub props.
Hughey .187 Assembled Cable for 3/16" Propellers $23.99 1$23.99 [ ]
This is a good size for that power.
Carbon Fiber Turn Fin Set $22.95 1$22.95 [ ] Sub Total: $271.85 Delete
To small for the 29. I would use the metal larger fins.Product ID: tfl-506b71
As far as props go, its impossible to make exact recommendations. The problem is that every setup(depending on how its built) and water conditions are different.
If you shattered a ul-1 prop, you probably hit something. If it was metal, more damage would have been done. I would suggest some Graupner 2317 props.
Start with a 2317.40 and work upwards with testing.
If you don’t want carbon filled props, start with a Octura x440 and work upwards in size.
Steven
OSE
Must be A.D.D. That was a short "while"
