My new Sniper mono
  • kevinlew211
    • 706
    My new Sniper mono
    My new Sniper mono, Neu 2230, 10s2p and 12s2p, Just want to share some pics to all
  • ozzie-crawl
    • Sep 2008
    • 2943
    very nice, i personally think these are one of the nicest looking mono hulls around
    what speeds you looking for?
    • kevinlew211
      • 706
      i want to see 75mph+ on 12s, but let see how this mono handle at that speed.
      • ozzie-crawl
        • Sep 2008
        • 2943
        i have seen the video of peter zichas (yes i still dream of owning that boat ) and besides a bit of chine walk looked very stable at i believe 65 mph would love to see yours do 75+
        • z400
          • 1333
          Sexy
          Z
          KBB34" Mono - Fast
          ToySport Triton- Not as fast
          • kevinlew211
            • 706
            Mark's boat video:
            i have alot of power to build my mono after watch his run.
            • ozzie-crawl
              • Sep 2008
              • 2943
              now thats insane any idea on speed with that mono
              • Punisher 67
                Ignore list member #67
                • 1616
                Very nice so far Kevin , I definitely want to watch this build and run...............
                • kevinlew211
                  • 706
                  You was right, his mono is name "Insane" also, btw, that video was 81mph and he has another pass with 89mph and he holded a record with that.
                  • kevinlew211
                    • 706
                    Peter, just like you, i dont race, but i still want my Sniper look like your from inside
                    • ozzie-crawl
                      • Sep 2008
                      • 2943
                      89 mph thats fast real fast. i think any of use would be very happy with a boat that looks and goes as well as peters
                      • Paul Pachmayer
                        • Jun 2009
                        • 219
                        Hi Kevin,
                        Did you get that hull without rails? Just a suggestion, you should really consider running the rails about 4 inches past the cowl opening. The way you have it set up you run the real risk of cracking the hull. The other thing I noticed is your rudder, it looks to me like it's a lighter weight 21/45 size. Could be the picture but if it is that size you may find the first time you swap ends with the boat that bracket will bend. I've bent Speedmaster brackets and their allot thicker than the one your using.
                        Paul.
                        • Punisher 67
                          • 1616
                          Mark threw the rotor on that motor also pushing it at 2 x 14S getting it to 89mph at a saws event..................
                          Kevin I have to agree with Paul the hull is tough but thin
                          • kevinlew211
                            • 706
                            i got the hull from someone and yes, it was no rail, i have to make the rails myself, but under those lipos, there 2 piece of thick wood mount down to the hull and connected to the rails, 1st to mount the batteries, 2nd to make to hull stronger, i think now the boat just like the want with rail or even stronger , and im using 67 size rudder and but its kinda thin, now im worry
                            • Paul Pachmayer
                              • Jun 2009
                              • 219
                              Hi Kevin,
                              I wouldn't worry to much, the worst thing that would happen is it would bend and you would have to replace it. It will control the boat and as long as you don't swap ends at high speed you'll be fine. Who knows, you may luck out and never have that happen to you.
                              Believe me when I tell you your going to have to do more to reinforce the bottom of that boat. I've built over a dozen of those hulls for customers and a roughly 18 pound boat traveling at the speeds you want simply will not survive a hard stuff or big blow over. Not only do I run full length rails I also tie the rails in to the bow with urethane foam. The bottoms and decks of the boats I build do not compress under the stress of a hard crash.
                              Let's put it this way, any place on the hull that you can make flex by pushing on it with your hand can and will break sooner or later.
                              Paul.
