How much gap are you guys leaving between the drive dog and the strut? I am running a 150 cable on 2.5 hp. How much does the cable shorten under this much power?
driveline slack
driveline slack
ReddyWatts fleet photo
Mean Machine - Feigao 540 14XL, 8s, 100 amp HV esc, X537/3Tags: None
depends on what cable you run.
if its a hughey then i would leave about 1/6 of a inch . maybe just a bit less.
if its a h&m flex then leave 1/10 th inch of a gap.
Octura cables
Thanks, Driven, that is about 1/8 of an inch. Suggestions are 1/6, 1/8, and 1/10 or 2, 3 or 4 mm.
I am using a 10 inch, 150, Octura cable that Steven sells. I wish there was a way to calculate flex shrinkage.Last edited by ReddyWatts; 06-13-2007, 01:01 PM.ReddyWatts fleet photo
Ok, thanks guys. I will use the 1/8, 3mm gap on octura cables.ReddyWatts fleet photo
