1/8 hydro setup
  • U.L. HYDRO DRIVER ICE
    • Apr 2008
    • 270
    1/8 hydro setup
    I have 1/8 scale hydro and would like to know which motor to use a neu 1527 or 2215 and how many lipo cells do I need to run.I would like get speeds around 70mph
    How many kv to
  • Ub Hauled
    • 3051
    are you planning in racing oval or SAW? I think you'll find out that 70mph will be a tall order in either case... I think the SAW record is 58mph and some change from '07...
    but it's not all bad, people have been achieving higher speeds... not too much higher though.
    There are three schools of people as far as motors go... there are that think the 1527 is the motor to go and think that the 2215 is too heavy and fast for a scale boat... and there are the 2215 owners. The third group is trying alternate motors.
    I guess it'll all depend on how much $$$ you wanna sink into the boat (no pun intended). You'll need a max of 10s and 10,000mAh if you wanna compete and doors are open if you wanna just play around. Oh, don't forget the ESC, that will have to be something that can take the "heat".
      • Apr 2008
      • 270
      Which kv should I use in 1527 and this is for playing around no rules
        • Apr 2008
        • 270
        Could two 5s 5000mah packs work 30c rating
        • Ub Hauled
          • 3051
          If you really want 70mph, then the 2225/1.5Y on 12s2p is more suited... your hull better be big to fit all this... what hull is it?
          You should spend the money and get a good ESC to handle all that power.
          I think, just to be on the safe side, 2x 5000mAh (35c) minimum.
            • Apr 2008
            • 270
            phil thomas and can I use the 1527 neu (which kv )to get in the 50s . how many lipos do I need for this setup
            • Ub Hauled
              • 3051
              1527/1.5Y on 10s1p (35c cells) or 10s2p (25c) in a way where it comes out to be 200amps discharge...
              • crabstick
                • 955
                plett bm370 is another proven option for a 1/8
                http://www.youtube.com/watch?v=U32pikSS-yc - 79mph
                http://www.youtube.com/watch?v=HR0RVhK-xO0 - flip and recovery.
                This boat belongs to a friend of mine, and is VERY fast and impressive to see. Probably the only one of its kind in New Zealand at the moment.
                Matt.
                www.rcboats.co.nz
                  • Apr 2008
                  • 270
                  How many mah
                  • Ub Hauled
                    • 3051
                    something that will turn out to 200 amps constant...
                    like this:
                    8000mAh for the 25c
                    6700mAh for the 30c
                    5700mAh for the 35c
                    5000Mah for the 40c
                    • Ub Hauled
                      • 3051
                      that is a FAAAAAAST 1/8 scale... also REALLY well setup...
                      • crabstick
                        • 955
                        it now runs 12s2p.
                        Matt.
                        www.rcboats.co.nz
                        • Rumdog
                          • 6667
                          That hydro is soooo sweet!!
