Kinnda weird question..???
  • nate
    • 1652
    Ok this may sound dumb, and never heard this being mentioned so Ill throw it out there...
    I was really thinking hard about ordering a small higer RPM neu motor for my tunnel hull today,
    but will I have any problems with water getting inside my motor... is this an issue on other outboards..
    will it effect anything..?
    LMT
    LehnerMotorenTechnik.com
  • Meniscus
    Refuse the box exists!
    • Jul 2008
    • 3222
    The real question is, how far in the water will it sit when it flips?
    • Darin Jordan
      • 8332
      Well... if it's on an outboard... it's going to get water inside...
      It's only a problem if you don't clean it back out after it happens. I think the bearings are the main thing...
      What I do with mine is flood them with Corossion-X before I run them... and then I blow the motor out when I'm done and put more Corossion-X in there... Seems to be working fine to this point.
      Darin E. Jordan - Renton, WA
      • nate
        • 1652
        Well Ill be running the Bullet drive, a Neu 1512 2.5d on 4s2p, Hydra120 and an x445.
        I just didnt want anything to go wrong if small amounts of water got down in the motor as I ran a few minutes..
        Darin,
        So spray corr.X IN the motor before runs.. do i spray it in then blow it all out with like a compressor or what do you suggest...
        LMT
          • 7277
          I have had motors submerged, full of water and they keep on running during races. Like Darin said, the bearings are the main thing to worry about
          • Darin Jordan
            • 8332
            I spray it in there good, then go run the thing...
            • nate
              • 1652
              Nice ok thanks
              LMT
