Feigao 540 L
  • vvviivvv
    • 1148
    Feigao 540 L
    ok, i just bought a drifter s for £150 got the hull shaft strut rudder and a 40mhz micro receiver + servo
    ive got a AS26-150BL esc i can use... for another boat but it's all i got at the moment and since the other thing isnt built yet i might aswell use for now
    i was planning on 'copying' a set up ive seen before; basically a 540 12L on 5s with and octura x442 prop
    but i was told a feigao 540L only went up to 4s? i would like to run on 5s it will be water cooled
    the 540xl is not a option as its 5mm too long to fit
    i just want to know if a 540L will be ok on 5s... if not its gonna be a hacker motor or a lehner going in good job i dont pay for all this
    Uk SAW record holder
  • video200
    • 840
    the drifter S wil fit a XL with ease.
    my drifter S is running a 8XL on 4s
    but i would never run a L motot on 5s. 12XL on 5s sounds more like a plan.
    • vvviivvv
      • 1148
      unfortunately the motor mount came already glued in... but i suppose i can buy a xl try it and if not
      • video200
        • 840
        cant you borow one first and se if it fits ? maybe a local club or something ?
        • vvviivvv
          • 1148
          i made a cardboard cut out which was about the same size put double sided sticky tape on it and it stuck to the lid when i tried to shut it but ill order 1 and see what happens
          thanks.
          • video200
            • 840
            but do you need to run 5s ?
            a L motor on 4s wil move that boat pritty good as well.
            • vvviivvv
              • 1148
              got 8 kokam 5s 5000mah 30c battery's which cost a considerable amount of cash and im trying to run as many things as possible off them i suppose 2 4s' wouldn't be the end of the world :| but ill try and fit a xl motor in 1st
              • video200
                • 840
                guess you can use a L motor. but i would go higher then 12L.
                but i think some of the guys on here would know that better then me :)
                • vvviivvv
                  • 1148
                  sorry... but would it actually take 5s i know like the graupner motors said 9,6v on them but they operated from 7,4v to 16v ish im pretty contempt on using 5s and if not 12L what would u propose ?
                  this boat goes well... http://www.youtube.com/watch?v=wc51X...eature=related
                  • nate
                    • 1702
                    12l= 2084kv... 5s would kill that motor in less than a few runs if the esc dont go first...
                    My SV with a 12l on 4s with an m447 is pushing the heat..
                    Use 4s with a 442...
                    mid 40's
                    LMT
                    LehnerMotorenTechnik.com
                    • vvviivvv
                      • 1148
                      mid 40's
                      which motor : a xl a L what windings?
                      • Mel279
                        • Dec 2008
                        • 873
                        Hey Bro
                        U can use 5s on feigao 12L as I've seen someone using it on the drifter s,
                        here is the video that I've found from the youtube
                        • vvviivvv
                          • 1148
                          i got a 8xl which is fine on 4s and hyper on 5s im not even going to try 6s lol...
                          • Mel279
                            • Dec 2008
                            • 873
                            If u want to go for 6s, use lower kv motor like 12xl 1390kv like I use on my drifter s y'day with hydra 240A, prather 220(43mm). Here is the video, sorry for the poor quality video...enjoy
                            • video200
                              • 840
                              Originally posted by Mel279 View Post
                              Hey Bro
                              http://www.youtube.com/watch?v=wc51X...om=PL&index=20
                              you CAN use 5C on a 12L. but that dont meen you should.
                              thats 40 000+ rpm on fresh batteries and i realy think that is pushing it way over the limit.
                              if you have to use 5C on a L motor you should atleast go for the 14L so you might keep it for more then 5 runs.
                              just my $0,2
