Hey, new here, but I'm sure many know of me.
If not I converted a Villain IV into a jet boat with a 700sc motor, tekin marine 432m esc and 12 cells.
I just switched to a feigoa 12L and decided to use the SV27 esc. Since it seemed to fit the amp rating on the esc and motor. I'm using a graupner jet drive, with a 29mm impeller.
Well, it doesnt work, I plug the batteries in, turn the radio on, put it to full throttle, get one beep, I return to neutral and get 5 quick beeps. If I slowly advance the throttle, she'll fully rev up. However if I push the throttle quick she quits before maybe 5,000rpm. As soon as I put the boat in the water and hit the throttle in any manner, it quits, immediatly.
I havent a clue, the shaft spins freely, I used gold connectors for the motor to the esc. My batteries though a modified sport pack of NiMH 2400Mah cells, are put together with deans bars and 12gauge wire. I'm using a so far very reliable Futuba ATTACK SR stick type radio.
The motor is rated for a max of 51amps. and the esc is rated for 45amp, pretty close. My 700sc never got past warm after a 7-8 minute run on the 2400's. Figured maybe that motor pulled 20amps average.
Anyways I know thats a lot to read, but I'm new to brushless, but not to this boat.
I'm also a very loyal customer. :)
Greg
p.s. a video showing the trouble in a test is uploading. you'll see when ever the motor gets a load, it quits.
Greg
. Here's some old videos, she moved, you can also see the water is pretty aerated. I actually tried tossing the boat today.....nada
