Can't get the solder to stick to the motor case???????
soldering capacitors
I assume you are installing these on a brushed motor.
Are you using solder flux and is you solder iron capable of heating a large area like the motor case?Grand River Marine Modellers
Originally posted by Doby View PostI assume you are installing these on a brushed motor.
Yes,brushed motor.Using flux maybe the problem is the case is not hot enough?/I'll give it another shot.
Just stating the obvious here but my modified 540s all had painted cases, you scratched the paint off before trying to solder right? My 40watt weller was up to the job on 540s and 700s.Paul Upton-Taylor, Greased Weasel Racing.
I agree with Paul , scuff up the solder point with a dremel or a small file some motor cases are plated also , should stick way betterNecessity is the mother of invention.............
