eBay Hydro Build
  • nate
    • 1702
    eBay Hydro Build
    Thought about buying this little hydro on eBay and running the AQU Motor and esc with an X445 on 4s.
    Ill be picking up and the Mini hardware rudder ect. from OSE, then maybe paint this little beast a hot pink lol
    Would it take this setup or is that to much for 16"
    http://cgi.ebay.com/16-hydro-plane-f...3286.m20.l1116
    LMT
    LehnerMotorenTechnik.com
  • Diegoboy
    • Mar 2007
    • 7443
    That thing is comparable in size to the Minicat Racing hydro & hydromite. a 540 motor will not fit under the hood I'm afraid.
    • nate
      • 1702
      Diego do you think a lower set mount like this one will work so that I can run a 540...
      http://www.offshoreelectrics.com/pro...rod=grp-1157.2
      LMT
      • nate
        • 1702
        I can always use a nice bend in the drive...
        LMT
        • JimClark
          • 5913
          I got to look on the calender are we back to April Fools day?
          Jim
          Billy Graham
          • Diegoboy
            • Mar 2007
            • 7443
            you will have to consider the size of the esc as well and the batts. after all that, you have to wonder if it'll still float.
            • Rumdog
              • 6667
              run a feigao 380 or 380l. 540 will not even be close to fitting.
              • 785boats
                Wet Track Racing
                • 3423
                If you look at their website they also sell the boat as an ARTR with a 2604kv motor, for a 3s setup with a 50A ESC. The motor size looks to be a long 380 size I think. They don't specify. They claim 85km/h on a 30mm prop. All for $160.00
                Here's a link for comparison.
                http://cgi.ebay.com/16-hydro-plane-A...3A1%7C294%3A30
                • Flying Scotsman
                  Fast Electric Adict!
                  • 5195
                  [QUOTE=nate;96727]Thought about buying this little hydro on eBay and running the AQU Motor and esc with an X445 on 4s.
                  An X445 and that power, as Jim stated is it April the first again?
                  If you are jesting, then say so. As some guys may follow your suggestions.
                  Douggie
                  • nate
                    • 1702
                    Jim
                    Your such a funny guy, haha so funny. Nice that you took the consideration to answer a few questions on subject.
                    This was an Idea, Just a simple question if this setup would work... Nobody said it has to work.....
                    If you ran a smaller mah 4s lipo it should still be buoyant enough to keep one 4s lipos and a motor and esc not much bigger or heavier than the original setup on the one aRTR for $160.00.
                    LMT
                    • nate
                      • 1702
                      [QUOTE=Flying Scotsman;96751]
                      Douggie
                      Jesting, Just say SUGGESTING.
                      LMT
                      • nate
                        • 1702
                        Now that I think about it, I was never suggesting this setup to anyone..... or was I douggie?
                        LMT
                        • z400
                          • 1333
                          Nate ive still got that 380 Ammo motor that will work very well in that boat.
                          Z
                          KBB34" Mono - Fast
                          ToySport Triton- Not as fast
                          • Doug Smock
                            • 5359
                            Nate, snatch up the yellow hull. Price is right.
                            http://forums.offshoreelectrics.com/...ead.php?t=8365
                            MODEL BOAT RACER
                            IMPBA President
                            IMPBA 19887L CD
                            NAMBA 1169
                            • JimClark
                              • 5913
                              Ok seriously I doubt you would be able to keep that setup on the water if it would float. There is a an awfull lot of torque in that motor. That setup motor pushes 1/10th scale hydros 36 inches long and 6 pounds rtr at nearly 50mph on a 4s 5000mah
                              Billy Graham
