Oct.V/937-3 935- qUeStIoN!!
  • nate
    • 1702
    What prop would work best on the 1515 1.5y on 5s....
    The V/937 OR 35..
    Will these be better to run on 5s than the x442-445 on a hydro??
    LMT
    LehnerMotorenTechnik.com
  • J Solinger
    • Apr 2008
    • 197
    The V series props have so much lift I couldn't make them work. They would cause my hulls to hop like crazy. Your better bet would be to go with a little cupping on a 440 or 442
    Joe Solinger
    • Ub Hauled
      • Aug 2007
      • 3051
      I have had good results with the 937 and the 935 on riggers... keep in mind they need different shaft sizes, the 935 is 1/8 shaft and the 937 3/16.
      They do have a good amount of lift and are not meant to be used for long periods of time, they will draw a good amount of amps and generate a lot of heat.
      For longer runs they will not be better for a hydro then the other mentioned props, you'd be better off using a 445 and maybe a 642. Also like Joe said working the prop a bit you may get a good result of a smaller 440 or 442.
      If you must go with a V series just for short "wow" runs, I think the 937 would work, but start with a 935 to get a feeling for it w/o burning stuff up.
      • detox
        • 2357
        Using 5s with a NUE 1515 1.5Y your combo will spin an unloaded rpm of 28,500. I would try the simple M445 prop by Octura in your Phil Thomas SS 21.
        My combo using 4s with a NUE 1515 1y will spin an unloaded rpm of 32,560 rpm. I am using the smaller Grimracer L38 x 55 in my UL-1. Speeds are approaching 60mph with that setup. I think my UL will haul the mail faster using the Grimracer L40 x x57/3 prop.
        • Ub Hauled
          • Aug 2007
          • 3051
          M series are great props... just sharpen/balance and play.
          • Diegoboy
            • Mar 2007
            • 7443
            I had a V935/3 cut to a V932/3, It made my renegade rigger into a renegade rocket!
            • Meniscus
              Refuse the box exists!
              • Jul 2008
              • 3312
              I tried the V935/3, not cut down as Diego did and I tried to burn stuff up. You know I'm going to try again though, with a little different setup!
              • nate
                • 1702
                Thanks for all the help on these props guys, Iv learned alot in this thread already.
                Greatly Appreciated!!
                Well the Idea was to get the fastest 3-blade prop for my Neu setup, I think it would be great to swap up props real quick and do a couple of short, on and off fast runs on the v/937.
                I was planning on running the X442 the first time I run this setup, then move up a few and see what prop really hauls on 5s without alot of heat or damage.
                I was watching Youtube, and I looked up this prop, there are very few video's
                of this prop in action, could be a reason tho.
                There was a video with a Votex hydro running the V935, Feigao 540l 2235 and it hauls the mail as Diegoboy says.
                Of course this is a whole diffrent setup that Im using. Watch the vid, Im sure some have already seen it..
                LMT
                • Ub Hauled
                  • Aug 2007
                  • 3051
                  I have detongued my 935 a bit... have not had the chance to try it yet, but it should work just fine.
                  • HOTWATER
                    • 2419
                    Danny, did egneg cut that prop for you? I gots to get me one of them thar blades made!
                    -Kent
                    "Will race for cookies!"
                    IMPBA D12
                    • Diegoboy
                      • Mar 2007
                      • 7443
                      Egneg does ALL my props. Yes he did!
                      • Ub Hauled
                        • Aug 2007
                        • 3051
                        Danny, chk out the SX4000 thread...
                        • Diegoboy
                          • Mar 2007
                          • 7443
                          Nothing new, What's up?
                          • HOTWATER
                            • 2419
                            Thank you Danny! Hope all is well (without the well beloved Graupner SX 4000)...Taylor will surely hook that thing up!!!....BUT...We want Video!!!!!
                            egneg...I HAVE A SMALL JOB FOR YOU!!!
                            -Kent
                            IMPBA D12
                            • egneg
                              • 4759
                              -Kent
                              I just ran across this thread and Hotwater I would be more than glad to do a prop for you.
                              IMPBA 20481S D-12
