Hi-model 200 amp 8s problems
  • Rumdog
    • 6667
    Ok,so I traded for this esc a few weeks ago. I'm just now to the point of installing it in my latest build. Running 6s with a receiver pack. Red wire is unhooked. Programming is very similar to the etti esc's. So, I go into prog. mode. Set lipo cutoff for 6s, then try to go to the next set of variables and the esc starts beeping like crazy. couldn't get it to stop, then I noticed it got real hot, really quick! Immediately unplugged the batts and the esc from the motor. About a half hour later I plugged it all back in and same deal. I didn't give it a chance to heat up much this time, but I could feel it rapidly warming. I couldn't get it to stop rapidly beeping. I'm at a loss!! Is this thing shot?? Please Help!!
  • domwilson
    • 4412
    Did you download the manual from? here...http://www.himodel.com/electric/HiMo...-200A-BEC.html
    Government Moto:
    • Rumdog
      • 6667
      Yes, I did.
      • domwilson
        • 4412
        I know this is a dumb question, but is the motor good? Have you tried a different receiver/radio? Try eliminating all the other variables first. If everything else checks out, I would assume the problem is with the ESC. I just got one of these but haven't hooked it up yet. It may just be a bum ESC.
        Government Moto:
        • Rumdog
          • 6667
          Thought of that. I did switch the receiver/tx. Same thing. Could actually be that it's the motor. I'll check it out.
          • eboat
            • 726
            Did you try running the esc when you got it before you tried programing it ??
            • Rumdog
              • 6667
              Motors good, tried a diff. good motor and same thing. Before I tried programming I did hook it up and try it, but just got the continuous beeping. I'm lost. I think the esc is bad.
              • ksm2001
                • 397
                It shouldn't get hot just by programming if you have the heat sink on. The continuous beeping sounds strange but its a bit tricky at first to go through the settings even with the instructions... so many beeps to keep track of, but it may be a bum esc
                When you connect the batteries it will play a tone followed by 2 beeps telling that's its armed and ready to go. Does it do that?
                I have 2 Himodel 200's, both are water cooled and sealed in plasticote. One was completely submerged in water on my rigger and it runs fine after drying out the boat, the other I run in my DF 29, motors are 7xl and 8xl, logged them both with the eagle tree using 4s lipos and peaks at 114 amps, temperatures are just warm.
                http://forums.offshoreelectrics.com/...ead.php?t=5924 (post #5)
                Ken
                DF-29,Phil Thomas Super Sport 45, SV27, Xzess 2 Evo, HOTR 32" Cat
                • Rumdog
                  • 6667
                  It is watercooled and has an extra etti cap bank. I got it to arm once, then entered prog. mode. changed the lvc. after that, nothing. Seems weird. Even before I tried programming, It wouldn't arm, which seems odd. I even switched from my 2.4ghz rx to a fm27mhz and no change.
                  • Boatman
                    • 875
                    any odd chance these need piStix with some radio?
                    • Rumdog
                      • 6667
                      Crud!!!! This isn't looking good! SOOO close to getting her on the water too. I wonder if the guy I got it from had issues with it. Seems he may have!
                      • Rumdog
                        • 6667
                        No Pistix req'd for this esc.
                        • ksm2001
                          • 397
                          No you shouldn't need a piStix, I use a Spectrum dx3 on mine with no problems.
                          • ksm2001
                            • 397
                            Sorry to hear that about yours
                            • bustitup
                              • 3072
                              I got that esc in a Titan 40 I bought here in the forums ...when I received the boat I ran it the next day and had no issues at all....the only reason I traded to you for your etti was because I hate esc that need programing by beeps....funny part is that the etti is the same way but I didnt know that till I agreed to trade with you
                              I assure you I would never sell something that I new wasnt working and I knew for a fact that it works
                              you can check my rating on ebay my username is nickwild2003 and I have a super rating and have never screwed anyone
