Noob questions about what motor/esc combo
  • vag_nutter
    • 10
    Ive got a kyosho dolphin2 outboard and want to set it up with a brushless, wjat motor and prop should I use?
  • Simon.O.
    • Oct 2007
    • 1611
    This is going to depend on so many variables.
    What boat will it go on ?
    Are you looking for outright speed or to have a fun boat with good run time.?
    What battery packs do you have now if any ?
    I have the Academy OB and run it on the F1 tunnel so I know the outboard that you have. I had a Kyosho one a while ago too.
    If you have a photo of the boat that would be good or at least a name or model of the boat that you have.
    The more info that you can give the better the advise that you will recieve.
    • vag_nutter
      • 10
      I was going to run it on a hot shot tunnel hull for now, I just want something that is quick and fun, dont have any lipos atm, just nimh
      • Simon.O.
        • Oct 2007
        • 1611
        The hot shot tunnel is 27" long if it is the one I think it is.
        For fun you could go with a S size BL motor with a 1/8"shaft that will be a direct bolt on to the existing OB unit.
        Then grab a Mystery 100A off e-bay and run 6-7 Nimh cells to it.
        If you are going to go with brushless then I can strongly reccomend that you go lipo too, unless you have some very good Ni cells and the will to care for them.
        It took me a long time to go BL and even longer to go Lipo. Now I do not look back.
        The price of the higher power systems is so low these days that is it is a no brainer to go BL+Lipo.
        If you must stay with Nimh then go for a 8S and feed it with 6-8 cells
        If you choose to go Lipo then go with a higher wind (12S) and use 3S Lipo.
        These are reccomendations based on what I have and run.
        Hang about and I am sure there will be other ideas too.
        • vag_nutter
          • 10
          What size prop should I be swinging? I just realised your in nz aswell, who is the best place to get parts from locally
          • Simon.O.
            • Oct 2007
            • 1611
            If I were to run that hull on a S size BL Motor I would be looking at a 432 for kickoff. Do not give that OB too much stick as it will give it back.
            Trust me If I had that hull the first thing to go would be the Kyosho leg.
            Yes I am a Kiwi too.
            Local supplies are a bit tricky.
            When I can I will use High Performance Models in Browns Bay on the shore.
            I get a few small bits locally on line from a variety of suppliers here in NZ.
            Big items such as motors and ESC's and battery packs come from overseas.
            OSE (here) is a good place for most of that the rest can be found online.
            Search or ask and you will find.
            • vag_nutter
              • 10
              Will the kyosho leg not handle it? Ive got a spare k&b 3.5 lower unit it could possibly modify
              • Blackjack-sven
                • Feb 2009
                • 396
                If I'm not mistaken the K&B 3.5 is a nitro No? not sure how you want to modify this. Is there an adapter for this or are you thinking of making one? I ask because I have the K&B 7.5 and was thinking of doing something similar.
                HK Genesis, DF Vortex, Baja 5T, Lazer ZX-5 sp, XXX, 8T, P51-D Mustang Shangrila, GP Giant P51-D Mustang, Blade 400 3D, with way too many more to list.
                • vag_nutter
                  • 10
                  Yea you can buy adaptor plates for them
                  • Simon.O.
                    • Oct 2007
                    • 1611
                    I believe you can buy adapter sets for K&B lowers.
                    When I ever get hold of one I will do the conversion myself.
                    With that lower you can easily run a S motor but you could also move up to the SV power package.
                    There are a bunch of threads here about tunnels. The VS-1 and TS-2 spring to mind. Find them and have a good read about OB conversion and suggested power setups.
                    You are going to be a bit higher than what I have experience in.
