Bilge Pump?
  • M.M.
    • 271
    Bilge Pump?
    Do thye have a sort of thing that will pump out or sifen the water out of your hull?
  • Rumdog
    • 6667
    Autobailer, get one here on ose. Shouldn't have water in a fe boat though.
    • M.M.
      • 271
      Ok, i just have a problem with water coming up through the teflon stuffing tube and im afraid of too much water coming in.
      • ozzie-crawl
        • Sep 2008
        • 2943
        some boats seem to pull more threw than others always found by adding a fair amount of grease fixed it for me
        • Rumdog
          • 6667
          Grease should help out for sure. if it's still syphoning in water drop a lil' sponge by the stuffing tube so that little bit of water gets trapped and doesn't flow around the hull.
          • ozzie-crawl
            • Sep 2008
            • 2943
            yes the sponge works well. i dont use grease as such but a product called lanotec (made from lanolin) its water proof and used in high temp high pressure machinery. works great and never had any rust on my flex cables.
            • M.M.
              • 271
              OK, i will try filling the tube with grease. Gotta have a well lubed shaft.
              • ozzie-crawl
                • Sep 2008
                • 2943
                • M.M.
                  • 271
                  I have some marine lubricant for 1:1 boats, can i use that on here?
                  • Rumdog
                    • 6667
                    that stuff works well for me
