cooling question ?
  • supafastsupra2
    • 103
    Why would you run from a hotter component to a cooler one? This will heat up the cooler component. ESC first, Motor second, period. Also your theory about how heat flows in electrical components is wrong. Heat is waste energy that occurs where there is resistance. The Motor has the highest resistance followed by the speed controller's MOSFETs and then the batteries internal resistance.
    • Blackjack-sven
      • Feb 2009
      • 396
      So your telling me that the internal resistance of the battery won't be the first to warm up??
      If you turn on the hot water tap, does the hot water in the lines not heat up right at the tank first??
      Electricity moves EXACTLY the same way as water.
      HK Genesis, DF Vortex, Baja 5T, Lazer ZX-5 sp, XXX, 8T, P51-D Mustang Shangrila, GP Giant P51-D Mustang, Blade 400 3D, with way too many more to list.
        • 9481
        So one should run cooling to esc then motor always?
        That's what I was thinking
        I want to run a second cooling line on my Mean Machine, not sure the best way on a Cat?
        • Blackjack-sven
          • Feb 2009
          • 396
          I'm doing the same on my cat that I'm doing on my Vortex. I'm running 1 line in and splitting it three times to go to my motor mount, esc, and cooling jacket and the exiting via 2 exits. Here's a pic of my boat now. In all honesty I would run three pickups and three exits to my stuff so that it all gets cooled with the same temperature and volume of water. This would slow the boat down a bit as there is more stuff in the water but it also means you'd be capable of running more powerful props, batteries or motors. The amount of cooling may not be enough to prop up or get a faster motor. but if all your looking for is a fast fun boat where everything stays cool, by all means run as many inlets as you have components to cool. I'm designing a cooling plate for my batteries so that I can pull more amps faster.
          • sundog
            Platinum Card Member
            • Feb 2009
            • 940
            Blackjack, I'm pretty sure splitting it 3 ways would reduce its effectiveness - reducing flow to one third and not cooling anything well. You should keep it simple. Esc to mount to motor and out. The esc will heat the water the least, followed by the mount, then by the water jacket. My 2 cents for free. Sdg
            Legend 36 sailboat, KMB Powerjet Ed Hardy Viper, ABC jet pwrd BBY Oval Master, ABC Hobby Jetski, NQD Tear Into's, HK Discovery 500, MickieBeez pwrd Jet Rigger!, Davette/Gravtix jet sprint, KMB Powerjet Pursuit, NQD pwrd Jet Catamaran!,Steam pwrd African Queen, Sidewinder airboat, Graupner Eco Power
            • Rumdog
              • 6667
              esc first always. Most expensive, most fragile. doesn't matter whats hot first. do we water cool batteries?....NO. In fact Many believe it is good to preheat lipos, including myself. One pickup in most cases will work perfectly fine. If you are pushing your equipment that close to the limits, you need to change your setup, not your cooling.
              • Rumdog
                • 6667
                In fact, more splits means slower flow. Which means more time for that water to pass thru the components allowing it to heat more. One line with high pressure flow, flowing quickly supplies cooler water because it is not slowly trickling across hot components and heating up.
                • tharmer
                  • 342
                  So I sent the water first to the component that is running the warmest, then to the one that is next warmest, etc. This gives most cooling to hottest component. Of course for me no component is dangerously hot so it is sorta moot.
                  -t
                  • ozzie-crawl
                    • Sep 2008
                    • 2943
                    . if your getting heating problems then there is some thing not rite. on some of my boats that pull less than 100 amps i use a 200 amp esc un water cooled, just the cheap himodel ones. have pulled 160 amps out of these with out water cooling no problems
                    • SLOW
                      • 37
                      Im kinda new to the forum here but i'll add my 2 cents.
                      I have 2 water pickups on my SV-27, i run one to the motor and the other to the ESC.
                      then both converge in a Y fitting and flow out one exit.
                      It seems to work well, if anyone sees anything wrong with this i would like to know but it has worked quite well.
                      • Diegoboy
                        • Mar 2007
                        • 7444
                        Slow,
                        If you have dedicated cooling for each device, why skimp at the end? Run 2 exits.
                        Using one exit, If you loose cooling to the ESC via a blockage or a kink, for example, you'll still show exit flow from the motor pickup, and not know there's an issue.
                        • ozzie-crawl
                          • Sep 2008
                          • 2943
                          yes i would run 2 exits just in case your getting more flow threw one inlet but if you dont have heating issues then i wouldnt worry
                            • 9481
                            That's what I want to do on my Mean Machine...
                            When my MM goes by I can see water comming out of the exit but not like how I had it comming out of my SV27 with an external pickup, not using the rudder pickup..
                            I am not sure where a good place to put a different pickup on my MM ?
                            • Blackjack-sven
                              • Feb 2009
                              • 396
                              OFF TOPIC
                              Why on earth would you want to warm up your batteries before running them and getting them hotter. Does this not cause more problems?
                                • 9481
                                Originally posted by Blackjack-sven View Post
                                OFF TOPIC
                                Some say you can get more punch out of the packs!
