My DF 33 seems to really run wet in the right hand turns. If I angle the right turn fin away from the hull will that do the trick?
Hey all you mono experts
Tags: None
Ray, turning "wet" on the DF 33 seems to be the norm. Mine, as well as all others I've seen racing or playing pretty much just plow through the turns with a fair amount of bow wave. The front portion of the hull hardly tapers upward like, say, a Lizard EX or Rico hull so it stays pretty wet in the turns. Just be carefull to not crank in too much rudder or it will hook. Boatman's suggestion may help some.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Ditto, mine runs wet in turns in either direction!Grand River Marine Modellers
First of all clamp a long straight edge on the turn fin or fins and be sure they are parallel to the keel of the boat . if not , make them parallel .
Two things to try . Tucking the rudder in ( when the keel is level the bottom of the leading edge of the rudder is forward of the leading edge at the keel. )will lift the bow in the turns .
If your using trim tabs adjust or bend up the outside of the right trim tab up a 1/16th or so .
Either or both can lift the bow in the rt turn .
Wet up
I've got a mono that wets up when I turn LEFT..
I suspect trim tab placement.. I've played with it a bit, and it helped, but I feel I need to raise it like .5mm
