Lipo ballancing
  • wamf
    • Mar 2008
    • 75
    Lipo ballancing
    After reading a thread about unballanced lipo's I decided to check my own. Several of them are off by 4/100th of a volt. It's mostly the budget chinese variety. However I noticed that the better ones I had that were perfectly ballanced prior to charging weren't ballanced perfectly after charging.
    I am using the hyperion eos0606i ac dc charger. The warranty is about to expire, should I be concerned?
    Thanks
    MikeV
  • G Doggett
    • 477
    Lipos will get out of balance with use but if you let your Hyperion charger run long enough with the balancer connected it should automatically correct this.
    I never disconnect my lipos from the charger until I can see that all cells are at 4.21 volts. If a cell is still higher or lower than this let the charger do it's thing.
    Graham.
    • wamf
      • Mar 2008
      • 75
      Graham.
      Thanks I'll try that.
      MikeV
