Does anyone have any suggestions from start to finish for painting a boat? Including type of paint that works best? thanks
Paint??
Tags: None
Clean boats surface then scuff boats surface using Norton Gray 000 fine synthetic wool pads (Homedepot sells them). Prime surface using regular Krylon primer. Scuff primer using these same 000 fine pads. Then paint using Regular Krylon paint(Homedepot or Wlamart sell it). I always try to spray outdoors when the weather is good, no wind, low humidity, and plenty of light to see by.
...Last edited by detox; 05-15-2009, 09:01 PM.
I just used primer, paint, and clear coat from my hardware store ( not RC brand stuff) and it worked well on my ABS hull.
anyone use this stuff on fiberglass? http://www.krylon.com/products/fusion_for_plastic/
It's specific use is for plastic however is SUPPOSED to be good for fiberglass as well, just wanted to see if anyone has tried this before i get to paintn'.. thx
I have used it with good results. The red and white were done with Krylon Fusion.Originally posted by jingalls007 View Postanyone use this stuff on fiberglass? http://www.krylon.com/products/fusion_for_plastic/
Edit: I forgot to add that I used an automotive clear after the artwork and a bearier coat.Attached FilesIMPBA 20481S D-12
I'm building a blak gel coat boat ....means I won't have a black windshield......so i'm thinking of chrome for my windshield
Krylon have chrome? If so any good or any suggestion?SPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
did the Fusion "need" a clear coat do you think? Krylon claims that it doesn't need a clear coat.Originally posted by egneg View PostI have used it with good results. The red and white were done with Krylon Fusion.
Alsa has a product but it is a bit costly for what you want as one spray bomb is about $40.00 usd.
IMPBA 20481S D-12
No but the paint I used for the other artwork did. I also have to say that the clear did add quite a bit of depth to the overall paint job.Originally posted by jingalls007 View Postdid the Fusion "need" a clear coat do you think? Krylon claims that it doesn't need a clear coat.IMPBA 20481S D-12
I am actually debating the same question right now and was tossing around the idea of using Mirrored Auto Tint as a windshield instead of chrome paint.Originally posted by bustitup View PostI'm building a blak gel coat boat ....means I won't have a black windshield......so i'm thinking of chrome for my windshield
