Prince Mono Hull
  • ED66677
    • 1300
    the problem with these ARTR is that you never know what you're gonna get, some guys have had good result with this 25" boat some did not last more than 30 second!... just woshhhhh and smoke!...
    and as I mentionned the rest of the hardware doesn't seem to be top quality stuff.
    to me buying the ARTR or building it myself makes no difference, the most difficult will be to fine tune it at the end!!!
    if you're afraid of all this then buy a second hand boat that fit in your budget and that has proven its performances!
    Emmanuel
    • ozzie-crawl
      • Sep 2008
      • 2943
      if your going to just buy the hull and add your own hardware there is plenty of info here on the forums, but if your unsure of anything when you get the parts start a build thread with it and people will give you step by step directions.
      i know you are tossing up between the cat and the mono i have both, if it was me i would go for the mono but a 29" version like ed66677s
      great handling and somthing you could up grade later you could use the esc and batteries you have run between a 8-9xl
      • ED66677
        • 1300
        yeah the 29" size (mono or cat) is not too small so that it's easy to fit everything in and not too big so that the budget remains pretty low, mine is not a reference as I did the hardware myself but still I'm happy with the result/speed, latest video here, for few more $ you can get here at OSE the 29" DeltaForce (not a copy) witch must be even better, copies are made of vinylester or polyester/fiberglass, original are made of epoxy/fiberglass witch is stronger, Steven, here at OSE, has the appropriate hardware, motor (Feigao 8XL) and ESC (100A xpower), K42 carbon prop... and a good service... priceless!
        Emmanuel
        • ozzie-crawl
          • Sep 2008
          • 2943
          that moves out real nice ed, gotta ask tho dont you run trim tabs?
          • ED66677
            • 1300
            nope! cog is around 190mm from transom witch is pretty far back, no idea about speed, next sunday may be if my buddy shows up with his GPS
            Emmanuel
            • ozzie-crawl
              • Sep 2008
              • 2943
              just noticed a bit of chine walk in the video my 25" used to do that as i have the batteries up along side the motor added trim tabs and it stopped. lools like you have good speed a x642 prop should see you close to 50mph
              • ED66677
                • 1300
                before I spend more bucks in expensive props, got to invest in better batt, those are cheap chinese I got on e bay , and yes I may add tabs soon!
                X642 that's more pitch, I might try an S42 carbon that has same dia. and pitch! watch out amp draw then!
                Emmanuel
                • ozzie-crawl
                  • Sep 2008
                  • 2943
                  i have a 7xl in my 32" cat with a x642 was only pulling 79 amps max
                  • ED66677
                    • 1300
                    last records, Eagle Tree said 97A peak but that was before I move the cog as far as possible, need to plug it in again!
                    Emmanuel
                    • ozzie-crawl
                      • Sep 2008
                      • 2943
                      97 wow didnt think it would be that high. had a 25" mono pull 160 amps over 2000 watts
                      • ED66677
                        • 1300
                        yes but that the peak and as the pond is small ar straight run are short ET logger doesn't show accurate values, I believe the average is around 80
                        that's a lot man!
                        Emmanuel
                        • old yeller
                          • Apr 2009
                          • 21
                          not polyester
                          Originally posted by ED66677 View Post
                          ... for few more $ you can get here at OSE the 29" DeltaForce (not a copy) witch must be even better, copies are made of vinylester or polyester/fiberglass, original are made of epoxy/fiberglass witch is stronger...
                          very true what you have said,
                          but the chinese knock-offs ARE epoxy FRP.
                          • ED66677
                            • 1300
                            mine is not for sure, smells almost as strong as polyester, I guess it's vinyl ester!!!
                            might be time for Steven to make some ReadyToBuild combo with proven hull/motor/ESC/hardware for newbies!
                            Emmanuel
                            • bustitup
                              • 3072
                              can I get some suggestions for some K series props for this mono with a ul-1 motor and hextronix 120amp esc on 4s maybe 5s
                              • ED66677
                                • 1300
                                this mono is 29" long and I'm afraid the UL1 motor will not have enough torque, in the UL-1 page it seems 40mm props are the one, also the motor is a 36-56, on my 29" I have a Feigao 8XL, same KV as the UL-1 motor but 36-74 size and I'm spinning a 42mm prop.
                                also the UL-1 is an Hydro so much less drag than a mono, IMO the UL-1 motor would fit better in the 25" mono see here
                                Emmanuel
