Prince Mono Hull
  • M.M.
    • 271
    Prince Mono Hull
    Well i am looking to get back into the boating scene, but i dont have tons of money to pour into a boat. So i found this prince boat and i was wondering what anybody thought about it? The one that i like is the race spec version:
    http://cgi.ebay.com/25-deep-vee-ARTR...3A3%7C294%3A25
    Or would i be better to buy a cat? like this one:
    http://cgi.ebay.com/32-catamaran-ART...3A2%7C294%3A25
    I already have a turnigy 120A brushless ESC and programming card. And i plam on running to 2s 5000mah lipo's. Wired to make a 4s.
  • Boatman
    • 875
    Both have proven themselves nice boat hulls and hardware. HOWEVER the motors they are putting in are kinda "bastard" motors as they are cheap and easy to find. I would buy whatever you like and put in what you KNOW will work. The Prince looks sweet to me but, there again plan on buying at least a motor from here on ose. If not even a esc perhaps and x power 70A. It will be soo worth it in long run. I would suggest perhaps a 540 S can and again the x power 70A. Then you will have to decide on lipo or nimh. either way it will be sweet.
    • Boatman
      • 875
      got ahead of myself. Since you have the equipment you do I suggest the cat. I just like cats.
      • M.M.
        • 271
        i like cats too, but i was told that they needed smoother water. I will be driving in moderate waters though.
        • Tony
          • 420
          I think hydros need smoother water... I ran my cats on choppy water with no problems. Mine are 26" and 32" so maybe it handles a bit more stable than smaller size cats.
          • M.M.
            • 271
            So if i did get that 32" cat it should handle the rough well? What about flipping? Will my 120A esc work well in it?
            • ozzie-crawl
              • Sep 2008
              • 2943
              if you buy either you need to ditch the motors
              on the mono you can run a ammo 2300 with a x440 prop or some guys are running fiego 8xls both will work with your esc.
              if you go the cat you can run a 8-9xl
              • ED66677
                • 1300
                go for the hull only, get any good hardware and a Feigao, you'll be on a budget!
                I have the 29" mono with Feigao 8XL 4S1P cheap 100A ESC and I get this
                some guys are saying that the chinese hardware, especialy the strut/stinger, are not very good quality...
                FYI the 32" cat is a copy of the H&M Agitator... very good design!
                Emmanuel
                • ozzie-crawl
                  • Sep 2008
                  • 2943
                  if i was going to buy the hull only i would look at the real delta force hulls steve sells not much more but better qaulity
                  • ED66677
                    • 1300
                    that's right!
                    Emmanuel
                    • bustitup
                      • 3072
                      I would get the df from ose but he's out of stock
                      Many crucial things are out of stock
                      Steve any idea when these items will be back?
                      • M.M.
                        • 271
                        so what do you guys think about just the hull and hardware? I would most likely work a deal to get either of these boats without an electronics. So which hull is better, and what about the hardware on it?
                        • old yeller
                          • Apr 2009
                          • 21
                          China 25" mono
                          Bought one of the Chinese 25" DF mono knock-offs this past winter. Nice hull.
                          The little outrunner and esc were s-canned.
                          Gutted the hull, reinforced the bottom, and built a motor mount to fit a UL-1 motor.
                          Fitted a Castle 120 for control (2 x 2s, 5000 mah)
                          Hardware:
                          the drive (flex w/ squared end that fits into the front of the stub shaft & strut ... not the "stinger type")
                          was sloppy as a .... and folks reported that it broke easily.
                          I trashed that, replaced w/ a Hughey flex and home-made bushing cartridge.
                          The strut needed to be drilled out to fit the new arrangement.
                          Also lopped the 'nose' off to fit a brass piece.
                          The rudder is nice ... but had to lengthen the bracket to align the rudder L.E. and drive dog.
                          To do it over, I'd buy a bare hull and maybe a rudder ... source the rest elsewhere.
                          (hope to get the boat wet pretty soon)
                          • M.M.
                            • 271
                            I wouldn't mind doing it that way, by buying the hull and adding different parts to it. But this is going to be m first boat build so i don't know how hard it would be to mount the motor mount, as well as drilling holes in the hull. If its not too hard then i will buy just the hull.
                            • old yeller
                              • Apr 2009
                              • 21
                              build
                              I built a couple of FE boats @ 20 years ago.
                              MY HAVE THINGS CHANGED !
                              So this is my first attempt to get back into the game.
                              The most important part, IMO, is not the actual job/work itself
                              (pretty basic skills and tools – drilling, gluing, and etc.)
                              but having the knowledge assembled at hand to put it all together correctly –
                              hopefully the first time around.
                              A search here on OSE and elsewhere will give you a ton of "how to" info.
                              Or if there is a local club to hook up with ?
                              Finally, it's up to you to decide if you're up to the task.
                              I will add, that there is a LOT of info about this particular boat on the web,
                              and some are running the "as it's sold" racing version ARTR and having fun with it –
