Feigao motor
  • hkusp45
    • 308
    WOW! Looks good!! What hardware are you using?
    NAMBA #581
    Q mono NAMBA record holder
    'REMEMBER SOME PEOPLE ARE ALIVE SIMPLY BECAUSE IT IS ILLEGAL TO SHOOT THEM'
    • Steven Vaccaro
      Administrator
      • 8932
      Originally posted by ED66677 View Post
      here are the graph with amps and volts but no rpm cause I don't have the sensor yet!
      I'll purchase it next month as well as some IB4200 :D
      the first graph is with 2x12xGP2200 in parallel
      the second is with 12 cheap 4000 nimh... much better voltage, higher amps and 600grams less than GP's
      these runs were done on a narrow canal so each 5 second peak correspond to approximately 230-250 feet of run
      it's great to be able to compare isn't it!
      Its amazing how far we have come in the last 10 years. Good work. Now the fun part is finding the right prop.
      Steven Vaccaro
      • ED66677
        • 1300
        hkusp45, all is home made, only the prop shaft is Graupner M4 an fit in 4mm flanged ball bearing from RC car or helis mounted in thick wall aluminium tube, coupling between motor and prop shaft is made from H&M 4mm-4mm, a piece of 4mm flex and a 4mm-5mm coupling.
        Motor mount, servo mount, rudder mount are made of 2mm alumium, rudde ris 3mm alu
        ESC cooling plate is made of the same 2mm aluminium on witch a 6mm plexiglass milled (4mm deep W shape) with my home made CNC, water tubing is SMC clear PU 4x6mm tube
        Motor cooling is a fiberglass tube (from an American powder spray gun body) and the motor is just maintained by two silicon seal (rectangle section)
        Steven, I'm running a K40,5, with the single pack of 4000 (Camelion RC car pack), the thing weight "only 2.3Kg (5lb), I don't really want to go for some expensive prop like Prather or Octura, I know this could help but budget is budget! As I'm pulling 68 constant and 76 peak, I don't think I'll get any better with any other K or S prop! what do you think?
        Emmanuel
        • Steven Vaccaro
          Administrator
          • 8932
          If you are happy with the speed than you have to look no further. but there may be props that are more efficient are working than your current ones. Metal octura props are not that expensive if you balance them yourself. Which from looking at your work, you are well capable of doing.
          Steven Vaccaro
          • ED66677
            • 1300
            i'm happy with the speed, the only thing I noticed during the last few runs, I feel like the bow is very heavy, but there's simply nothing in front of the hatch/motor, so I thought about the prop shaft, I'm going to replace it wy a flex drive, I think because the prop is pointing downward (not horizontal) due to the shaft angle, it's lifting the stern, it's not dramaticaly bad but as there's not step on this hull, this might change pretty much the "wetness" and the thing might be a bit more "aerial"!
            Emmanuel
            • ED66677
              • 1300
              Those cheap batteries are Camelion, anybody has ever heard of?
              Emmanuel
