OK... I KNOW there is a way to get these stinking 5mm to .078" set-screw style couplers to work... but after loosing THREE different shafts... AND the props associated with said shafts... I'm ready to throw them in the dumpster and find something better...
I KNOW, however, that people have success with these things, so if you don't mind, could someone please tell me HOW they do it? I KNOW that I had the set-screws as tight as I could get them.. and yet... the shafts just keep falling out the back. WHAT could be the deal? Am I suppose to put "flats" on the wire? I'm getting REALLY tired of losing props...
And, for the second part of my question... Does ANYONE make a collet style or Octura style coupler for 5mm to .078" wire?
Thanks Guys... After winning Heat 1A of 1/10th scale today... I was out front in heat 2A when the shaft and prop just disappeared... Then, after changing couplers and putting in a new shaft... Prop two and the shaft dropped out again... And, again, I had them as tight as I could get them.
Help!
If no one makes a collet style coupler... They SHOULD! Enough people are using .078" wire that these should be standard parts...
