Medusa Motors, anyone using them?
  • Adrianli
    • May 2007
    • 47
    #76
    Originally posted by EPower View Post
    do you have a link to the website ?? Thanks
    Adrian
    Not sure if OSE allows it here.
    Here it is : http://www.etti.com.hk/index.php?cPath=5
    Steve, please delete this if it is inappropriate.
    • B-DAWG
      • Apr 2009
      • 42
      #77
      Here is a good review of them. I'm going to take the plunge and order one. http://www.e-savage.com/forums/showthread.php?t=2648
      • Brod
        • 196
        #78
        Originally posted by LuckyDuc View Post
        Did you have a custom motor made to order?
        No,just a 80mm 1600kv and a 80mm 2000kv...
        Brod..
        Slow gets boring fast.
        • Brod
          • 196
          #79
          [QUOTE=Adrianli;92890]Not sure if OSE allows it here.
          those Etti coolers work well,i have 2.
          Just smear some vaseline jelly on the orings when fitting,it also seals the can better.
          Brod..
          • LiPo Power
            DJI Drone Advanced Pilot
            • 3678
            #80
            ...this is fun to read....
            Canada
            • B-DAWG
              • Apr 2009
              • 42
              #81
              Here's mine after one weekend it didn't even make it to the 1 min. to check temps. I was testing prop sizes. The cap fell off on one run temp was 110 on motor I put the cap back on. Then went up 2 sizes on the prop and this is what happened after 40 seconds. I hope they have good CS or there goes another $100.00
              • LuckyDuc
                Team Ducati Racing
                • Dec 2008
                • 1058
                #82
                Wow. Looks like the thrust of the prop/shaft pushed the end cap off. Were you running a thrust bearing between the collet and motor?
                That same thing happended to my ARC motor. Thrust bearing prevented it from happing on future runs.
                • B-DAWG
                  • Apr 2009
                  • 42
                  #83
                  No, I wasn't using a trust bearing. You think that is what caused the cap to come off?
                  • LuckyDuc
                    Team Ducati Racing
                    • Dec 2008
                    • 1058
                    #84
                    Most likely.
                    • Brod
                      • 196
                      #85
                      Oh dear,that dosnt look good.
                      My 2 motors havnt come yet,i'll be using thrust bearings.
                      Brod..
                      • Adrianli
                        • May 2007
                        • 47
                        #86
                        I had two runs on Sunday and they were great as before. Running ard 45mph. Eagletree graph of both runs as attached.
                        • sneu@aol.com
                          • Jun 2009
                          • 7
                          #87
                          Originally posted by crrcboatz View Post
                          Boeing also chooses aveox motors and they no longer make rc brushless. Didn't neu buy them to IMPROVE their line
                          I can say that we did not buy the Aveox line of motors.
                          A little history lesson is in order. I have been friends with Dave from Avoex for a long time. We did help each other with brushless motors and controller designs over several years. I designed one of the early sensored controllers for Aveox. The 1.5 inch diameter stator motor which seems to be the subject here was never produced by Aveox. It was a result of work that we did to try and improve efficiency of their 1.4 inch hobby design. As we all know the design worked out quite well.
                          When Aveox decided to exit the hobby business in favor of the aerospace world I decided to get into making hobby motors. We took the 1.5 inch stator that Aveox and I had developed and used it in our line of motors. 2 years ago the 1.5inch motor design underwent a major refinement which resulted in improved motor efficiency and lower cogging.
                          Steve Neu
                          • sneu@aol.com
                            • Jun 2009
                            • 7
                            #88
                            Neu magnets are outsourced from China also. Would bet the wire is not usa either. Labor is US but who says the US has a patent on building good bl. motors. Plettenberg, and lehner are not made in the US either. Etti escs are not made here either, in fact I bet they are made in China with a european name put on them.
                            The main thing in outsourcing is QUALITY of parts that are used. Quality control is the key in picking the materials.
                            Food for thought
                            Magnets from China
                            Machine parts from USA,China and India
                            Stator steel from USA or Germany
                            Stator stamping from India and China
                            Bearings from Japan and China
                            Motor shafts from USA and China
                            Wire from USA
                            Stators wound and made in USA and Mexico
                            Assembled in San Diego
                            Designed in San Diego
                            Used around the World!
                            As you can see it we can be proud and say our motors are made on Planet Earth:)
                            Steve Neu
                            • Ub Hauled
                              • Aug 2007
                              • 3051
                              #89
                              Get the best what each country may offer, like a big tool drawer...
                              • crrcboatz
                                • Jan 2009
                                • 1103
                                #90
                                Mr. Neu,
                                Tnks for being honest with regard to materials and work to make your products. I think it clears up an misconceptions of neu motors.
                                As all can see it is almost impossible to make brushless motors today without involving countries from around the world, in order to make them in a price range the hobby can afford.
                                There should be room for competitors and medusa will find its place, I am sure of that.
                                Curt
