Some Grim Props are now in stock....
Tags: None
Polisher
What do I need to buy to polish my props like the grim racer line.ReddyWatts fleet photo
Its quite simple believe it or not. At my jewelry business we use this tumbling process all the time. We use something like this.
http://www.stuller.com/products/prod...spx?iid=294372
But there are hundreds of tumblers on the market.Steven Vaccaro
Is there a description for the numbers on the props? Does the first number give the mm size and second mean they are close to Y series props??? Please explain.
What grit do you recommend to get this type of finish? I guess you need to refinish them after balancing.
The polishing pads that came with my dremel tool work pretty good to refinish.Last edited by ReddyWatts; 05-31-2007, 09:18 PM.ReddyWatts fleet photo
No offence but why would they polish a prop without finishing it first. Too many newbie's are going to buy these props and think they are ready to go.Team Liquid Dash
The first number is the diameter in mm. Not sure on the second.Originally posted by ReddyWatts View PostIs there a description for the numbers on the props? Does the first number give the mm size and second mean they are close to Y series props??? Please explain.Steven Vaccaro
Originally posted by Steven Vaccaro View PostThe first number is the diameter in mm. Not sure on the second.
The numbering on the Grimracer Props (or ABC props) is Diameter (mm) x Pitch (mm)...
So, for example, the 42x55 is 42mm (1.65") in diameter with a 55mm (2.16") pitch...Darin E. Jordan - Renton, WA
