Ok
I was up at the Dallas Classic race May 2nd&3rd
Saw all the new LSH setups & said to myself
My old H&M Viper with 700 cordite, 12cell Nmh
.062wire drive 3/16 end just is not up to the task at
hand anymore :-(
Just as the title says
How much power can a wire drive take
I think I would like to put in a brushless setup now
Already have a UL-1 60amp esc & motor
would like not to have to pull my existing drive line
to switch to .150 flex
Appreciate the help
Mike
hand anymore :-(
Appreciate the help
Mike
Here's what I got : 31" H&M shovel w. 1515 1Y/4S. Shaft is almost completely straight, just a slight bend to the low-mounted motor. Running .187 cable to 5mm Octura shaft coupler. Length of shaft is 18" from front of shaft to motor side of drive dog. Runs inside brass tube with no teflon liner. Can I get a .093 that long, and how about a Octura-style coupler instead of setscrew type ? [ I've stripped so many setcrews in my time, and I assume lubing after every run is recommended so the setscrews will get used a lot ]. I don't mind paying for custom work if needed. What's motivating this switch to wire is that I'm of the opinion that there's way too much drag on a flex cable that long & puts undue stress on the motor. Also, will the install need a liner ? Post answer here, or if you'd rather PM me or E-Mail to
