Brushed/brushless Motor freezer
  • Mel279
    • Dec 2008
    • 873
    http://cgi.ebay.com/Motor-Cooler-Mot...3A3%7C294%3A50
    Can this be use on boat?
  • Steven Vaccaro
    Administrator
    • 8932
    Originally posted by Mel279 View Post
    Interesting. I'm pretty sure you would use it while at rest then remove it and use it. There are some engineers on the forum, wonder what they think of super cooling a bl motor?
    Steven Vaccaro
    • Jeff Wohlt
      • 2740
      I would be really worried about condensation in the motor after it is that cold and then getting hit with heat from the motor use.
      www.rcraceboat.com
      jwohlt5362@yahoo.com
      • Meniscus
        Refuse the box exists!
        • 3312
        Cool find!
        • paulwilliams
          • May 2007
          • 82
          I'd say that looks like a solution in search of a problem.
          Paul
          www.fastelectrics.net
          • Blackjack-sven
            • Feb 2009
            • 396
            I personally wouldn't worry too much about the condensation that could build up in the motor, because everything will dry out very quickly once warmed up. but unlike tire warmers which are intended to pre-warm the tires before they get even hotter, this product is trying to cool a motor before it gets hot. I can't see how long a motor would stay that cold since water will be going through the cooling jacket (witch will be warmer) and the heat of the motr will be contained in the hull.
            HK Genesis, DF Vortex, Baja 5T, Lazer ZX-5 sp, XXX, 8T, P51-D Mustang Shangrila, GP Giant P51-D Mustang, Blade 400 3D, with way too many more to list.
            • Jeff Wohlt
              • 2740
              Cooling a motor was very common in the brushed days and it WOULD run stronger longer because the mags were cold.
              www.rcraceboat.com
              • Blackjack-sven
                • Feb 2009
                • 396
                I understand the concept but doesn't the water in the cooling jacket warm up the motor while the heat generated from the motor get trapped in the hull? How long will the motor stay cool before it's back at normal temps again?
