Motor and Prop Charts
  • Blackjack-sven
    • Feb 2009
    • 396
    I haven't been able to find a motor chart (or Prop Chart) where the different prop and brushless motor companies are shown with other companies that have equivalent props and motors.
    IE. A 1500kv motor form Proboat is equal to a Neu 1515/0.5y
    IE. A Graupner M4 = Octura x447
    I know these two motors and props are very different, but it is just an example.
    HK Genesis, DF Vortex, Baja 5T, Lazer ZX-5 sp, XXX, 8T, P51-D Mustang Shangrila, GP Giant P51-D Mustang, Blade 400 3D, with way too many more to list.
  • Blackjack-sven
    • Feb 2009
    • 396
    lets see a chart as well for those people using brushed motors.
    • Meniscus
      Refuse the box exists!
      • 3312
      Sven, check out my thread here: http://forums.offshoreelectrics.com/...ead.php?t=5382
      It has motor specs in and comparison. You can also sort by column if need be. If you don't know how to do this, let me know and I'll guide you through it.
      • Blackjack-sven
        • Feb 2009
        • 396
        Holy buggers
        That chart is actually (compliment) WAY too involved. I'm gonna have to rip it apart and put it back together again in a super simple manner, but thanx for the starting point.
        Now that I have a motor chart to work with do you also have a prop chart, or know of any place that does?
        • Meniscus
          • 3312
          Oh well, I tried. I don't have a prop chart. Sorry. I think that we could all use the "guide to prop sizes and pitch"
          • Blackjack-sven
            • Feb 2009
            • 396
            The Graupner prop list
            Company Prop Diameter Pitch Material Shaft Size Blades Direction
            Graupner GR1124 35mm N/A Nylon 4mm 2 blade Right
            Graupner GR1125 35mm N/A Nylon 4mm 3 blade L or R
            Graupner GR1128 45mm N/A Nylon 4mm 4 blade L or R
            Graupner GR1129 45mm N/A Nylon 4mm 5 blade L or R
            Graupner GR230830 30mm N/A Nylon 4mm 3 blade L or R
            Graupner GR230835 35mm N/A Nylon 4mm 3 blade L or R
            Graupner GR230840 40mm N/A Nylon 4mm 3 blade L or R
            Graupner GR230850 50mm N/A Nylon 4mm 3 blade L or R
            Graupner GR230860 60mm N/A Nylon 4mm 3 blade L or R
            Graupner GR231050 50mm N/A Nylon 4mm 4 blade Right
            Graupner GR231060 60mm N/A Nylon 4mm 4 blade Right
            Graupner GR231432 32.5mm 1.2" Carbon filled Nylon 4mm 2 blade Left
            Graupner GR231440 40mm 1.2" Carbon filled Nylon 4mm 2 blade Left
            Graupner GR231442 42.5mm 1.2" Carbon filled Nylon 4mm 2 blade Left
            Graupner GR231447 47.5mm 1.2" Carbon filled Nylon 4mm 2 blade Left
            Graupner GR231450 50mm 1.2" Carbon filled Nylon 4mm 2 blade Left
            Graupner GR231452 52.5mm 1.2" Carbon filled Nylon 4mm 2 blade Left
            Graupner GR231742 42mm 1.2" Carbon filled Nylon 3/16th 2 blade Right
            Graupner GR231831 31mm 1.2" Carbon filled Nylon 4mm 2 blade Right
            Graupner GR231842 42mm 1.2" Carbon filled Nylon 4mm 2 blade Right
            Graupner RA3001 35mm 1.2" Fiberglass Filled Nylon 3/16th 2 blade Left
            Graupner RA3002 40mm 1.2" Fiberglass Filled Nylon 3/16th 2 blade Left
            Graupner RA3003 45mm 1.2" Fiberglass Filled Nylon 3/16th 2 blade Left
            Graupner RA3004 50mm 1.2" Fiberglass Filled Nylon 3/16th 2 blade Left
            Graupner RA3005 52.5mm 1.2" Fiberglass Filled Nylon 3/16th 2 blade Left
            Graupner RA3006 55mm 1.2" Fiberglass Filled Nylon 3/16th 2 blade Left
            Graupner M4 35mm 1.2" Fiberglass Filled Nylon 4mm 2 blade Left
            Graupner M4 40mm 1.2" Fiberglass Filled Nylon 4mm 2 blade Left
            Graupner M4 45mm 1.2" Fiberglass Filled Nylon 4mm 2 blade Left
            Graupner M4 50mm 1.2" Fiberglass Filled Nylon 4mm 2 blade Left
