Difference in a X and Y series prop
  • ReddyWatts
    • 1700
    It looks like the tongue is longer on the Y series prop. This is just the opposite from the M series, that has a shorter tongue than the X. Can someone explain what performance difference you should expect to see from a longer and shorter prop tongue?
    ReddyWatts fleet photo
    • 7990
    Tom has told me repeatedly that the only difference between the X and Y props is an additional 10% more pitch on the Y....blades are the same. You can expect a bit more speed with the Y and a bit more lift....usually. I find the M545 gives slightly more speed than the M645 on my LSH; the M545 is a Y545 without the tongue.
    The tongue is lower pitched than the rest of the blade, and it hleps the boat to get up on plane. I have no problem getting any of my boats on plane and remove the tongue on all my X and Y props - I prefer to buy M series from the start if I can. You will usually see a bit more speed from a prop with no tongue.
    • ReddyWatts
      • 1700
      Tongue
      The longer tongue helps accelerating out of the hole and a shorter tongue will get a higher top speed. Thanks!
      The previous picture was an optical illusion. I layed the props on top of each other and Fluid is correct, no difference. A Y537 prop is really a X537. So why didn't they just name them X437, X537 and X637 props. It would be a lot less confusing. Y? Y? Hmmmm.......
      How big is the guy that did that? I am looking for him. J/K
        • 7990
        He's the guy in the middle. Now don't you feel silly!
        • ReddyWatts
          • 1700
          I still wonder what he was thinking when he named it Y.
          • franktcs
            • 2
            Anyone have a picture of a tongueless prop
            • RMZDADDY
              • 379
              Here's a pic of an X645 (on your left) and an M645. The M series has the tongue cut down.
              • ReddyWatts
                • 1700
                X-M props
                Here is another picture of the M and X series props. X is on the bottom. You can see the difference, it is not alot.
                They are both factory Octura M and X 447 props.
                • franktcs
                  • 2
                  Does anyone remove more tongue than that? And what will be the effect?
                  • GeoRXT
                    • 45
                    Im sorry guys, I am new to this and by the pictures I really cant point out what the tongue is...? And how do you remove it?
                    • ED66677
                      • 1300
                      the tongue is the "front" part of a blade that is the closest to the shaft look at figure 2 here
                      Emmanuel
                      • GeoRXT
                        • 45
                        Can you do this on the stock prop?
                        • H&MWill
                          • 623
                          Is it plastic?
                          Many issues!!!
                          • GeoRXT
                            • 45
                            Originally posted by H&MWill View Post
                            Is it plastic?
                            Yes sir it is...
                            • lonewolf
                              • Jul 2007
                              • 658
                              Here is a place to read up on props. There is alot of other info at this site also.
