ESC connection question...
  • Ub Hauled
    • 3051
    So I have this 200 amp ESC that I will use with a 3060...
    I'll be using the "Triangle connection", the ESC has 2 wires
    per phase, on phase "1" two wires, each from a different board... same for phase "2" and phase "3". I was just going to hook up one wire to each connection on the motor and then it occurred to me that this may not be the most suitable way to do this...
    Any thoughts?
  • ED66677
    • 1300
    on this picture I would connect the two top cable together to the two cables from phase 1, same for phase 2 and 3...
    Emmanuel
    • Ub Hauled
      • 3051
      Thanks, but
      why would you do it? I'd like to know why... my thought is that it would over amp one bank of FETs, but I am not sure it'd be this way...
      anyone else care to comment?
      • ED66677
        • 1300
        you wont over heat anything, each wire of each board of the same phase have to be in parallel, as if these ESC were two 100A ESC in parallel, each board being 100A capable by a bunch of Fet's in parallel too, now for the motor coils, six connections that can be wired star or delta (also called triangle) is nothing but the same as a 400VAC triphase motor principle, each terminal is one end of one coil, in delta, each phase or board powers up one coil while in star, each board or phase powers up two coilc that are physically wired in serie
        Emmanuel
        • Ub Hauled
          • 3051
          thanks guys, this is what I am talking about.
