2.4ghz from Tower Hobbies $79.00!!
  • detox
    • 2357
    NO PROBLEM... The Tactic receiver will bind with any Tactic radio. Every radio should send a different signal. If your NEW receiver does bind to a radio on the pond other than yours, you can always rebind it to yours. Just make sure everyone elses Tactic radio is turned OFF while binding to your radio.
    • bustitup
      • 3072
      Originally posted by jimclark View Post
      which model reciever?
      sr3000
      • jingalls007
        • 1172
        speaking of binding, I couldn't get my receiver to bind near my computer or anywhere near a Wifi setup. I thought I was going nuts but finally got it to bind at the pond, no where near any Wifi.
        • Ub Hauled
          • 3051
          Mine bind's just fine near a computer, and wifi... I personally don;t have wifi but three of my neighbors do and I get their signal in my place pretty strong.
          • Jman
            • Feb 2009
            • 18
            Can you use more than one model with the same transmitter and more than one receiver?
              • 9481
              Yes you can..
              • Jman
                • Feb 2009
                • 18
                Thanks,
                How do you switch from one to the other?
                  • 9481
                  Are talking about the $80 radio from tower?
                  It does not have model memory so you would need to adjust your trims for each different model you run that radio with..
                  Not sure if I answered your question?
                  • Jman
                    • Feb 2009
                    • 18
                    I was talking about the one that comes with the ul. So you just bind all the receviers one at a time then which ever one is on you have to trim for that boat.
                    • properchopper
                      rcgoatbuild@snotmail.com
                      • 7708
                      I scored two extra receivers in mid March ; just put one in my H&M hydro ; works fine, plenty of range, no antenna & "bound" it within 6 feet of my wifi router for my wifi cellphone with no problems. Can't be beat for $ 24.95
                        • 9481
                        Yes, thats all..
                        • Flying Scotsman
                          Fast Electric Adict!
                          • 5195
                          I am still very confused here..not surprising. I thought that all 2.4 ghz systems would only bind to the rx and tx in use, regardless if another similar or exact tx was operating
                          Douggie
                          • Bill-SOCAL
                            • 1409
                            Within any given brand there really is no limit to the number of receivers that can be bound to a given transmitter. But you can only bind the same brand to the same brand, Futaba-Futaba, etc.
                            And if you turn all those receivers on at the same time they will all react to the control inputs from the transmitter they are bound to (JR/Spektrum Model Match is the exception).
                            And in all cases, once a receiver is bound to a certain transmitter it will only "listen" to that transmitter. You can re-bind receivers to other same brand transmitters as many times as you want to do.
                            Don't get me started
                            • Flying Scotsman
                              • 5195
                              Thank you Bill, that clarified my concern.
                              Douggie
                              • ghostofpf1
                                • 399
                                Originally posted by bustitup View Post
                                sr3000
                                From what I've read therein lies the problem.The sr3000 rx have problems with signal skipping over water that the sr3100's (In all 7 of my boats) do not have
                                hope this helps
                                Steve
