Idea - Energy recovery - Charging on board
  • DISAR
    • 1137
    I just had an idea which is not totally CRAZY!
    How about this. To have a charger inside the boat charging the batteries, and the charger to have power supply from the sea/water and speed of the boat. Kinetic energy transformed into electric.
    I am a few years ahead...
    http://www.rcfastboats.com/
  • ozzie-crawl
    • Sep 2008
    • 2943
    been thinking about plutonium power cells myself dont tell the greenies
    • DISAR
      • 1137
      As you have the cooling lines, there will be one for charging. Only the charger is missing
      IN: water
      OUT: +5 Amps, 2-...s
      • Meniscus
        Refuse the box exists!
        • 3312
        I'm thinking that the efficiency of the charger would have to be very high.
        It seems to me that if you were interested in generating power to charge the batteries, I'd do it with the motor. A brushless motor is using power to turn a shaft. If you turned the shaft with something else, then you'd get power (generator). So, why not put another set of windings around the motor to generate power while you're consuming it to turn the shaft? Yes you would use more energy than it provides, but it may lead to some longer runtimes or additional power available for the run.
        LOL!
        • DISAR
          • 1137
          Or to put another motor between coupler and flex, which will be the generator. In commercial ships it is similar, some they have a shaft generator.
          • AndyKunz
            • Sep 2008
            • 1443
            Wow, just think - you could remove the batteries and let the generator power the motor directly, and it would run forever!
            Andy
            Spektrum Development Team
            • 7500RPM
              • 110
              I was thinking Caterpillar drive, stealthy, never hear it coming.........
              There is no replacement for displacement, I guess I just have to Buzz it higher!
              • DISAR
                • 1137
                Andy
                I am not an electronics/electrics specialist but without the batteries you will have the boat steady in water forever.
                I just give an idea and someone who is well involved in the business of these motors-escs-chargers may come up with something in the future. Honestly, the thinking is correct the technology is missing. USA is far beyond in technology and we should see someting like that
                • cyberhoops
                  • Jan 2009
                  • 74
                  I like the creative thinking, but we are going to need some serious technology advances for this one.
                  We have a water towed generator on our Hunter 34 sailboat for crusiing. In this case the generator is able to produce about 12 amps to trickle charge the on-board batteries and it is only a small drag on the 3 ton sailboat. But it would not scale down very well to FE boats. Even at 80% efficiency the drag induced to turn even a small generator would be killer.
                  A generator and motor are very similar - and the amount of force needed to turn the shaft of a generator is much like trying to turn the shaft on one of our brushless motors.
                  Jim Stephens
                  Puget Sound Fast Electric Boat Club
                  • 785boats
                    Wet Track Racing
                    • 3423
                    What you are trying to achieve is Perpetual Motion where a motor drives a generator which drives the motor but still has extra power to drive a load. In this case your prop. A lot of wizards have tried but it hasn't been done yet.
                    A couple of Aussies have made a Zero Point Generator. Which basically produces energy from the magnetic ether all around us. Old Nickola Tesla was going to give the world free energy using his discoveries & principals until the "powers that be"shut him down. Just like they've shut these guys down.
                    Here's what you want just slightly smaller.
                    Do a google on Nikola Tesla... Electromagnetic generators.
                    And ...Scalar Technology.
                    Also... have a look at some of the videos on the sidebar of the one posted above. Like this one.
                    You'll be lost in there for a long time surfing around if you are really interested.
                    Paul.
                    • Meniscus
                      • 3312
                      Paul, did you see my picture album on Tesla? http://forums.offshoreelectrics.com/...php?albumid=34
                      I'll have to check out the links provided when I'm not at work and have time to read in depth, but what you explained is exactly what I was trying to get at.
                      • DISAR
                        • 1137
                        Very nice info, so there is "something" actually but for well "unknown" reasons it cannot be further developped. If it is free energy what the power and oil companies are going to do?
                        • egneg
                          • 4759
                          All that is needed is a flux capacitor!
                          IMPBA 20481S D-12
                          • Meniscus
                            • 3312
                            LMAO! I knew I could count on you Egneg!
                              Regardelss of what anyone thinks, immutable physical laws deny the possibility of true perpetual motion. You would be $$$ and time ahead to simply buy packs with a larger capacity, or run 4P.
                              Yep, just for you I do have a real nice bridge for sale......
