Hi all. I am getting ready to start converting a SW36 to brushless and plan to use the Feigao 580L motor. I have found a couple of motor mounts that I would like some more info on.
1.) Product ID: etti-h010 - Adjustable Motor Mount 540 Size
http://www.offshoreelectrics.com/pro...prod=etti-h010
Anyone have this mount? Could you be so kind to give me a couple of dimensions on it? I am looking for the width of the inside blue plate and the overall width of the mount with the side plates on it. Chances are, the blue plate will work and at worst, I'll make some new carbon fiber or aluminum side plates to get the right mounting width.
2.) Product ID: tfl-509b14 - Adjustable Water Cooled Mount for 380 to 540 Size
http://www.offshoreelectrics.com/pro...rod=tfl-509b14
3.) Product ID: tfl-502b12 - Adjustable Mount for 380 to 540 Size Motors
http://www.offshoreelectrics.com/pro...rod=tfl-502b12
Same questions on #2 and #3. Anyone have this mount? Dimensions of inside plate and overall width with the included side plates? I like the water cooled mount
I am hoping to find at the very least, a center plate I can use and I can make side plates to varying widths without much difficulty. Ideally I want to use the existing rubber isolated mounts where the nitro engine used to live. It does not look to be that tough, I would just like to get a grasp on the dimension of the above mounts so I have a clue what to start with.
Thanks for any info!!
I am guessing I'll use some sort of lower support just to keep it from flexing downward but I figured this part would be easy to do once I get the motor mounted.
