Perfect hull for Graupner Mini Jet Drive?
  • lomdel
    • 722
    What would be the perfect sub 29" deep vee, flat ride pad hull to install a brushless powered Graupner mini Jet drive (the one here one OSE) unit in? Would the Rio Roses be suitable?
    What is the rule of thumb for revs for Jet drives? I use 30k rpm for surface prop calculations...
  • Diegoboy
    • Mar 2007
    • 7443
    Rio Roses doesn't have a perpendicular transom to the bottom. This will require a great deal of modding to get the jet drive installed properly. I used the Pro Boat formula Fastech hull. It too is not perpendicular, the bottom has a slight angle to it. It took some finesse to get it installed I have also used the Pro Boat SW26. It was very easy & fun to do. Since the SW26 is ABS, it's easy to cut the hull, lighter, and faster running with a jet. There is already a thread here w/ video of that build (same drive)
    • Diegoboy
      • Mar 2007
      • 7443
      Here's the thread.
