Lipo cell over discharge
  • DISAR
    • 1137
    I was running 2 3s lipos in series i.e. 6s1p and when boat reduced speed immediately I brought it out of water, which meant lipo voltage cut-off. When I went home to charge them, the one pack has very low voltage ( abt6 volts) and when I measure the individual cells one cell is 0.5 volts! Do you know any way to recover this cell? Or where to buy a cell to replace it?
    My lipos were the Zippy Flightmax 3s1p, 4000mah, 20c.
    http://www.rcfastboats.com/
  • Meniscus
    Refuse the box exists!
    • 3312
    I have a couple of questions:
    1. Did you unplug the batteries when you were done with the run or did you wait until you got home?
    2. Have you tried to balance the cells and charge at .1 amps? When/If you do, please do yourself a favor and do it outside. Monitor closing and watch for swelling. Personally, I were safety glasses. What can I say, I like my eyes too much to let them go. LOL
    3. Any signs of puffing?
    • DISAR
      • 1137
      1) I unplugged them when I brought the boat out of water. I never leave them plugged.
      2) Tried to charge/balance charge at 0.1Amps but charger does not charge them in lipo mode. So I tried in NiCd mode at 0.1 Amps and charges it until 8.8 volts where it stops. At that point when I measure the cells individually one cell is 0.6 volts.
      3) No signs of puffing at all.
      Needless to say that I charge them outside and always keep an eye on them.
      You have any ideas?
      • Meniscus
        • 3312
        Well, I'm glad to hear that you do unplug them after a run. Do you have a separate balancer that you could see if it can bleed power from the other cells? Have you tried that?
        • Blackjack-sven
          • Feb 2009
          • 396
          did you try to force charge just the one cell or the whole pack? If you did the whole pack, try force charging just the one dead cell to 4.0v and then use the lipo charger to continue the rest of the charge.
          HK Genesis, DF Vortex, Baja 5T, Lazer ZX-5 sp, XXX, 8T, P51-D Mustang Shangrila, GP Giant P51-D Mustang, Blade 400 3D, with way too many more to list.
          • Boatman
            • 875
            My opinion: dispose of the pack or the cell if you are able to. I have never heard of charging lipo cell in nicd mode. I am interested in why you thought to do that. Is that a way of force charging? Really just curious. Thanks
            • DISAR
              • 1137
              I charged in Nicd mode as a way of force charging, in lipo mode the charger does not charge it because of "low voltage".
              I tried to charge only that cell from the balancing wires but it went until 0.7volts and today shows 0 volts
              That's why I am asking, if there is a way to save the pack or to renew the cell but i cannot find the same one.
              • Ub Hauled
                • 3051
                I am w/ Boatman, dispose and get another pack or cell... I personally would NEVER try charging in Nixx mode, different chemicals have different charging characteristics... Blackjack-sven, if you have done it, and got away with it, good for you man,
                just please don't tell other people to follow down this road.
                Have you ever seen a LiPo explode or burst in flames? I tell you man, Meniscus eyeware would not be sufficient to protect you.
                • hide
                  • Dec 2008
                  • 188
                  If its just one cell you can remove it, you probably have a dead cell.
                  • DISAR
                    • 1137
                    Ub hauled
                    I am not telling anyone to follow this. I am asking if you can help, and if somebody has had a similar case.
                    • Ub Hauled
                      • 3051
                      Originally posted by DISAR View Post
                      Ub hauled
                      Sorry DISAR, I did not mean you, correction has been made...
                      • Boatman
                        • 875
                        that stinks. Wonderful weather out there. hope you have more packs or can get some quick.
                        • 785boats
                          Wet Track Racing
                          • 3423
                          Boatman.
                          Charging an over discharged pack on the Ni Cd setting is an accepted way to bring a packs voltage up to the low level setting in the Lipo mode.
                          This should only be up to 3.0V not 4.0V though.
                          DISAR.
                          I had a pack once that one cell was like yours & after cutting off the heat shrink I found that the balance wire had broken off at the connection on the cell.
                          You may have the same problem. Also check the pin connection on the balance plug to make sure it is making good contact with the charger plug.
                          If not, it sounds like a dead cell.
                          If you can't find an equivalent cell you can remove the dead cell & make it a 2 cell pack. You will need aluminium solder though.
                          Good luck with it.
                          Paul.
                          • Boatman
                            • 875
                            Boatman.
                            DISAR.
                            Good luck with it.
                            Paul.
                            wow, thanks. That what I was thinking about a wire come loose or is shorted and is pulling juice from that cell.
                            • DISAR
                              • 1137
                              Many thanks, will take the heat shrink off and check it.
