Some bad luck with my motor
  • NorthernBoater
    • 869
    Took my boat out today and the first time I ran it seemed really slow and I brought it in. The motor would not turn and later on I noticed that one of the wires had some burnt strands on a wire. Has anyone heard of this happening on the SV27 motor? Is this something that I can fix myself or should I get Aquacraft to fix it? After going over it ,the wire looked to be the weak point in the motor. It looks like it is only about 16 gauge wire.
  • Steven Vaccaro
    Administrator
    • 8932
    If the outside shielding is burn, the inside windings are probably burnt. Is this a new sv boat you are running?
    Steven Vaccaro
    • NorthernBoater
      • 869
      No it was not new, I was running the motor in my Syncron.
        If the motor won't turn at all, the usual reason is a thrown/broken magnet. Then the wiring burns. The wiring is not a weak point of that motor, it is large enough for the intended use. A thrown/broken magnet is caused by over-heating the motor, over-reving the motor on the bench, a faulty job of attaching the magnets, or a cracked magnet. Remember, this is not a $250 Hacker motor, it is a cheap Chinese clone. It works well, but it is not bulletproof.
