Viper II design
  • line6
    • 510
    Viper II design
    I picked up a used H&M Viper II that i am rebuilding now. I am thinking about cutting the skeg off the bottom of the hull. I notice that a some of the other hydro designs don't have one. So I'm wondering if removing it and making the bottom of the hull flat will help or hurt anything. I don't know just a idea.
  • Ub Hauled
    • 3051
    can you place a pic please? I have a V II and never had an issue with the bottom, just wanna make sure it's the same bottom
    • tth
      • Apr 2008
      • 1600
      I believe he is talking about the "box" that the stuffing tube is aligned in to exit the transom. Am I correct in assuming this?
      • line6
        • 510
        yes thats the part i think it's called a skeg any way here is the pic
        http://forums.offshoreelectrics.com/...1&d=1240455072
        • tth
          • Apr 2008
          • 1600
          Damn,, that looks funny. Almost looks like it was made too deep. Mine is about half that depth.
          • teach
            • 509
            I am no expert but that really doesn't look like a typical Viper bottom.
            • Ub Hauled
              • 3051
              Dude, that is WAY too steep, mine is not even close to that... I wanna say that mine is about 10mm tall at the transom x 140mm long x 12mm wide.
              • H&MWill
                • 680
                Yeah same here on my Viper turbine. This is an old photo but same skeg.
                Many issues!!!
                • Ub Hauled
                  • 3051
                  Looks like mine! Oh, wait... it's the same hull,
                  • Boatman
                    • 875
                    Line6, I have one of those. It is an older, original version that FDM once sold that ran brushed motor with gear case and a huge prop is needed. Very fast and sturdy but I dont think brushless would power it inless you cut it off, after that well, I will be watching you cause thats where I have always stopped. What do you do after you cut it?
                    • H&MWill
                      • 680
                      Many issues!!!
                      • line6
                        • 510
                        It got the CHOP...
                        • Rumdog
                          • 6667
                          Nice job man!
                          • tth
                            • Apr 2008
                            • 1600
                            Good clean work. Do you mind me asking how you went about doing it?
                            • line6
                              • 510
                              Thanks man.... I first cut a piece of fiberglass cloth to lay on the inside of the hull to hold every thing together. I made this have about a two inch over lap and epoxied it in. Once dried i went to work on the bottom. I made i rough cut with my cut off wheel to remove the bulk of the skeg. Then i sanded the rest down with a carbide bit and a sand paper roll. Then finished it of with a palm sander. Then i cut a few, 1/2 inch by about 6 inch strips off cloth to fit in where the skeg was. To make it flat with the bottom of the hull. I glassed those in along with 1 large piece to hold it all together. I also put a extra layer of glass throughout the inside for added strength to the hull. Then sanded the bottom smooth. I will say where the skeg was is now the strongest part of the hull. I also plan to lay some carbon fiber on the inside off the hull.
