Which prop.
  • launchpad
    • 199
    Which prop.
    hello Guys;
    I have converted my miss vegas over to brushless motor and I need to know what prop would I use.The motor is 2075kv 90amp watercooled esc (2) 5600 mah 7.4 volt lipo batteries.With this combo I am not sure which prop would suit this application.This is my first conversion so you could say I am a rookie at this.
    Thanks for your help
    The esc has a 180amp burst rate.The batteries are 30c rating with 45 c burst. Al
  • Diegoboy
    • Mar 2007
    • 7443
    Did you convert the prop shaft to 3/16 or leave the 1/8 shaft?
    • Flyguy55
      • 218
      What motor do you have ? It will make a large difference difference .
      • Diegoboy
        • Mar 2007
        • 7443
        I'm going to guess it's an 8XL
        *** Yup. ***
        It's...
        Originally posted by launchpad View Post
        8XL x-power brushless motor
        Hextronic 120a esc programmable
        Aquacraft RX-100 Receiver
        Aquacraft SX-100 servo
        Aquacraft miss vegas trans
        2x2s1p 5000mah lipo
        • launchpad
          • 199
          miss vegas
          Hello there;
          The prop shaft is 1/8 inch.I still have the original prop which I do not think would work for me.I was looking at a Grimracer 42x66, or Octura M440.What do you think about them.
          Thanks
          Al
          • Diegoboy
            • Mar 2007
            • 7443
            They are both good choices, but you'd have to shim them. The Grim has more pitch.
            • launchpad
              • 199
              miss vegas
              Could you explain what you mean by shimming it up.I am still new to this hobby and I am learning mroe and more,as long as I ask..... I will be ordering the props from OSE,they have been good to me in the past.
              Thankyou for the info
              • egneg
                • 4759
                You need to put a sleeve in the prop to make it fit the shaft.
                http://www.offshoreelectrics.com/inf...propellers.php
                IMPBA 20481S D-12
                • ED66677
                  • 1300
                  the Feigao 8XL on 4S works fine with a 42mm prop (Graupner K serie less pitch than the Grimracer), your X-power certainly doesn't have the same efficiency so I would start with 40mm!
                  Emmanuel
                  • launchpad
                    • 199
                    Thankyou very much........
