Can I mount the speedo on top the batteries???
  • longballlumber
    • 3417
    Another question to expose my inexperience with FE setups…
    Is there any issue with mounting (velcro’ing) the Speed control on top of the batteries? I know many of you used to mount the controller on top the motor. The Hydra 240 LV is a hog, and I am in a really tight space. This going in my Vac-U-Pickle.
    Mike
  • Doug Smock
    • 5359
    I try to avoid it when I can but it's done all the time.
    What motor and cell count are you using??
    Doug
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • longballlumber
      • 3417
      Doug
      Hi Doug,
      Here is my set up. This is our club level spec N-2 class
      Hacker 8S
      2s1P 5000 mah or 2s2p 7400 mah (2 3700 packs)
      Castle Hydra 240
      ????? on the prop
      Fullers super strut
      .130 cable
      Speed Master rudder assembly
      Aquacraft turn fin
      Hitec 225mg
      Thanks
      Mike
      • Doug Smock
        • 5359
        Ok, I saw Hv instead of LV on your post, must have been too early.LOL
        Use the G-10 like they have suggested on RR. You may have to use a large RX pack right at the tramsom (or add weight) to get the CG right.
        Good luck with her and have fun!!
        Doug
        MODEL BOAT RACER
        IMPBA President
        IMPBA 19887L CD
        NAMBA 1169
        • longballlumber
          • 3417
          Where you guys running the CG at?
          • Doug Smock
            • 5359
            Set the CG right where the sponson webs merge back into the hull.
            Once you get it set and are happy with the boats attitude, mark the location of the cells on the hatch opening, that way it will be perfect every time.
            Doug
            PS Post some video!!
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
            • longballlumber
              • 3417
              Thanks for the Help!!!! Much appreciated!!!
              I will do my best on video.
