Need The How 2s For Putting CF Cloth In My Boat
  • crrcboatz
    • Jan 2009
    • 1103
    Can you tell me what to ask for and what type of vendor carries this epoxy? Also what do you mean by a 5/1 ratio in mixing. The only epoxy I have ever used was equal parts in the mixing process.
    Also, how does one keep the edges from raveling during the install process that requires a person to spread the epoxy out over it. I have found with glass work the cloth wants to ravel along the edges and can make quite a mess. Pics on this site of many of your boats inside show a very clean edge when finished, I would like to have that when finished.
    • knpc
      • 649
      Not a problem. I was on a short fuse anyway. I do the same thing. Things often come off different when writen as apposed to being said.
      Back to the topic at hand
      The stuff I use is called Clear-N-Simple made by NHP Co its epoxy finishing resin. I buy it at the LHS.
      Kevin
      Rico 29, Sprintcat 34, Insane FE 30 Hydro, 43'' Aeromarine Conquest
      • bustitup
        • 3072
        I'm pretty sure he said to use hairspray in the edges....sounds like a great idea because i was wondering the same thing....the darn CF allways wants to unravel...I will try this the next time
        • ghostofpf1
          • 399
          hope this helps
          Steve
          • crrcboatz
            • Jan 2009
            • 1103
            Thanks will try to find the stuff here in Tulsa tomorrow, if not will order it.
            • ozzie-crawl
              • Sep 2008
              • 2943
              this is a good thread,like i said very new to fibreglassing my self.
              the guy i get my cloth from said the best way to do c/f was to lay it on a panel of glass or perspex and use a pice of plastic or paint brush to push the epoxy in to the cloth, then use the plastic like a sqeegee and squeese out as much epoxy as you can then lay the c/f in the hull for some reason this is what i thought he said was pre preg . he showed me some hulls he had done this way, very light and strong.
              i would like to try this way but think it would be very hard to lay it in a hull with out it sticking to its self or parts of the boat and leaveing epoxy on places you dont want
              • Jeff Wohlt
                • 2740
                Curt, Z-Poxy is laminating epoxy.Most hobby shops have it. Thin yet very hard when dry. Sorry I did not jump in on your first request. Watch thinning anything as some will never harden like you would expect.
                www.rcraceboat.com
                jwohlt5362@yahoo.com
                • crrcboatz
                  • Jan 2009
                  • 1103
                  Will check all the hobby shops tomorrow for z poxy first then. tnks
                  • line6
                    • 510
                    I would not use Z-poxy for laminating a large area it is way to thick and tacks up to fast. I did a few test pieces about 4inc squares and it worked fine. I tried it in a mono hull and was not happy with the way it was coming out. This is just my experience with it. I now use epoxy i got from the local auto body paint shop it is much thinner and easier to work with and the dry time is is a few hours.
                    • crrcboatz
                      • Jan 2009
                      • 1103
                      Great idea! I have a auto body paint shop that supplies all my base coat/clearcoat stuff for my gas boat building. Will call them in the morning.
