Blackjack 55 coversion to electric
  • Blackjack-sven
    • Feb 2009
    • 396
    Seeing as Proboat decided to send me a new hull for the one that's broken, I figure it would be fun to turn the one hull into an electric 55, but I have no idea what type of hardware and electronics to use or where to get it from. I was thinking of making it a twin engine twin inline strut rudder system. Does anyone know where to get this equipment from?
    HK Genesis, DF Vortex, Baja 5T, Lazer ZX-5 sp, XXX, 8T, P51-D Mustang Shangrila, GP Giant P51-D Mustang, Blade 400 3D, with way too many more to list.
  • z400
    • 1333
    You will be fine with the stock hardware.
    Might look into the upgraded rudders by Aeromarine.
    that is one heavy boat, gonna need 2 big motors since you plan on running a dual set up.
    Look forward to spending some serious money on batteries if you havent already done so.
    Cant wait to see it moving.
    Z
    KBB34" Mono - Fast
    ToySport Triton- Not as fast
      • 7512
      Hope you have $$$$$$$$$$$$$$$$. You are going to need it to do a single motor conversion, let alone a dual!!!
      Siplest methoud, order the stock hardware from Horizon, or transfere you existing hardware. Use a single motor, a 3080 LMT or the big Neu, get 4 packs of 5S LiPos and a 240 HV Hydra or a Schultze speed controller, Figure about $3,000 as an estimate!
      • Blackjack-sven
        • Feb 2009
        • 396
        I think I'll go with 2 3080 LMT air cooled motors ($1200.00) and then add water cooling jackets (40.00) around them. I'll pick up 2 Hydra 240 HV's (1080.00) as I only have one regular 240. But where will I get the batteries from? What voltage and amperage would I be looking for? Would the MaxAmps 12000mah lipo's work?
        So far my bill would be $2320.00 without batteries.
          • 7512
          Minuimun Qty 4 , 5S LiPos of at least 5000mAh 25C rating. Connect in series and then parallel. If you are going with twin motors, figure about 3-4 minutes run time. As with any LiPo, get the higest capacity and C rating possible.
          • txboatpilot
            • 1805
            If you go with twins you will need 10s2p per side.. That is a total of 8x 5s 5000mAh 25/35C packs to get it done right.. You need 37V/10,000mah + per motor and esc...
            Nothing like keeping you lipos warm and your prop wet!!
            • Blackjack-sven
              • Feb 2009
              • 396
              The best battery I've found so far is this
              Battery: 10S-5000
              Volts: 37.0
              Max Cont Dischrg: 25C
              Max Burst Dischrg: 40C
              Max Cont Current: 125A
              Max Burst Current: 200A
              grm: 1250
              Dimensions: L x W x H: 170 x 48 x 89
              Does anyone know of a better battery?
              • txboatpilot
                • 1805
                Look at rclipos.com,,, They have a sale on PolyRC 10s 5000mAh 25c packs,, You will need 4 total..
                  • 7512
                  Rich, would you not need 8 to do the setup described in your post #6?
                  Nevermind Just realized you were talking about 10S packs!
                    • 7512
                    Battery: 10S-5000
                    Volts: 37.0
                    grm: 1250
                    Name or somethng would be helpful
                    • eboat
                      • 726
                      A 10S lipo battery is going to take a good charger to charge and balance and if you have 4 lipos you will need 4 chargers too so you can spend an hour charging again to run less than 10 minutes
                      I do not think you will just be able to pop the hood on the car and charge off the car battery either
                      • Blackjack-sven
                        • Feb 2009
                        • 396
                        Sorry but there seems to be no name for this battery, but this is where I got the info from. Check it out.
                          • 7512
                          • Flying Scotsman
                            Fast Electric Adict!
                            • 5195
                            John, this could be interesting.
                            Douggie
                            • jingalls007
                              • 1172
                              I wanted to do a Brushless conversion on my BJ55 a while back and was told that One Lehner 3080, One Schultz speedo (this was before the Hydra 240 HV was available from Castle) on 10s lipo would get this boat hauling a$$. I gathered this info from RCuinvierse a few years ago, you could probably still find the thread on there and that may be of help as well. Twin setup?? WOW!! Better do some hull reinforcing, the glass on the BJ is pretty thin.
