When I was running I misjudged shore turned and I ran over the mud a little bit. Luckly there was not much damage as can be seen in the photo. How should I fix it? I was think of filling it with epoxy and making sure it is smooth. Will this work?
Encounter with the shoreline
Tags: None
If just the gel is chipped off I would put a dab of med ca on the chipped area.
The reason I suggest ca is because some of it will wick into the hole and make a strong bond.Steven Vaccaro
Thanks for the input. I am just glad I did not wreck anything else. Is the one of the screws on the Speedmaster rudder supposed to snap so it will not break the rudder? Because the brass screw either broke or fell off before it went up on shore.
The speedmaster combo I purchased from you did have a brass screw on the bottom for the rudder. I am a bit confused on what you are trying to say.
Forgive me, I thougt it was a super vee. Yes the brass screw is there to break off.Steven Vaccaro
Maybe a little extreme but,..... Knowing me I would use white gel coat with red color added and mix It with cabisil for a thick texture. Let dry, wet sand and buff.
