Powering up a 70" mono
  • EPower
    • 417
    #46
    [QUOTE=Joern Markset;81528]Maybe.... A decent 35 cc cost about $2700 and for that price I get motor and esc + some lipos. I allready have about 8 - 10 chargers, powersupplies, and so on...
    I`ve been doing modelboating on a high level for several years, that`s way there is much equipment left... I never throw things away... I guess I have about 20 raceready boats... Monos, catamarans and riggers. Electric is missing so far...[/QU
    OH i did not realized you did elecric boating before What brand 35cc would you pay 2700us for ?
    • Punisher 67
      Ignore list member #67
      • 1616
      #47
      Adrian the actual length was about 6' or 15cm with absolutely no issues but have been shortened to about 4.5 inches or 11.5cm . the more critical length is from battery to ESC , The more capacitors you have on the esc the longer you can go ( to a point )
      • EPower
        • 417
        #48
        the ones on my motor are 15mm (1.5 cm) so you reckon i can make them longer, no problem ? you did add some extra caps on your esc ?
        • Joern Markset
          • Jan 2009
          • 231
          #49
          I have not been into electric boats on this level, but most of the parts are eqv with nitro/gas except from motor/esc/batt.
          Aprox $2700 is the price you gonna pay for a CMB or SG 35 cc in Norway.
          We are living in a country with skyhigh salery and 25% salestax!
          Joern Markset
          Fokus Racing
          • Punisher 67
            • 1616
            #50
            Adrian 1.5cm is 2/3of an inch are you sure you read that right , 6 inches to the motor should be safe with almost any setup
            • EPower
              • 417
              #51
              I just reread the motor manual it says no more then 150 mm (15 cm)
              • Punisher 67
                • 1616
                #52
                Not a problem Adrian..................
                • EPower
                  • 417
                  #53
                  Ok we must be lucky here in New Zealand we can get the CMB 35RS with pipe for about 1750 usd or 3000 nzd
                  • H2OCamel
                    FAST ELECTRIC EVERYTHING
                    • 494
                    #54
                    Peter looking at how anal you are on the inside layout of the boat is a work of art!!! Drooling ;-) well . . . . . . . . .let's just say large boat . . . .screams HighTech and FAST inside and out!!! 'nuf said!! :)
                    "Discussion is an exchange of knowledge; an argument, an exchange of ignorance." Robert Quillen
                    • Joern Markset
                      • Jan 2009
                      • 231
                      #55
                      NEU 2230/1,5Y is listed with max voltage of 72 volts, does that actually mean that the motor can handle up to 72 volts?
                      And if so, any ideas of where I can get hold of an esc capable of more than 60 volts?
                      Joern Markset
                      Fokus Racing
                      • Punisher 67
                        • 1616
                        #56
                        60 volts is as high as I have seen , a 2230/1.5Y even on 60 volts is going to be an animal
                        • Joern Markset
                          • Jan 2009
                          • 231
                          #57
                          I C, I`m reading lots of motor specs to get some basic knowledge while I`m waiting for the 2230 to be in stock.
                          In the meantime I have assembled a DF 12 (650mm) with CC 120 and Nemesis 9XL on 4S just to learn a little, and I ordered today a 1527 to power a Titan hull.
                          It is really fun doing something new when I have been stuck to nitro and gas for last 15 years
                          Joern Markset
                          Fokus Racing
                          • H2OCamel
                            • 494
                            #58
                            Joern,
                            I agree it is a blast to learn something new. It make life more fun and interesting. Have fun!
                            • DISAR
                              • 1137
                              #59
                              Our honor to have you here Joern. When you run your first electric it will be only electric then
                              There are some members here with big boats that can help a little, and we hope that you will share with us your experiences
                              http://www.rcfastboats.com/
                              • Ub Hauled
                                • 3051
                                #60
                                This means the it's the motors max rated voltage... running the motor with this amount of volts, will reduce the torque dramatically... like with any electric motor you don't wanna run at it's max rated voltage. Like Peter said, even at 60v this motor will be an animal. In case you have a hard time finding an ESC that will run all that juice, Castle Creations has what they call a SHV ESC (Super High Voltage ESC), that goes up to 90v and 250amps... now that's power!
