Drive hardware for twin cats
  • Simon.O.
    • Oct 2007
    • 1611
    Originally posted by lomdel View Post
    Simon. You have been at this twin cat thing for quite some time now. I do believe that at this stage you should be the one providing the solid suggestions as a result of your research into the matter.
    Lombard. You are correct on the point of my research. It is extensive and exhaustive yet non-conclusive.
    It would appear that Cats in this size are right between L and XL cans for power options as a twin setup.
    The biggest stumbling block I have come across is the measurement of Cats.
    Some measure to the transom rear and some to the end of the overhang ( if fitted )
    The 32"E-bay cat is just under 29"on the water.
    A MM is 29 on the water.
    These two hulls are quite different as far as aspect ratio and under hull shape.
    One thing I have found is that an XL can will beat a L can in torque and power with a minimal weight penalty.
    A pair of L cans is just ok for a 29"hull and a pair of XL cans is considered by some as quite wild. Here is where I draw the conclusion that this hull sits on the border.
    I can not comment on the Ammo Cans except that Scott (Ozzie-crawl) rates them well and his opinion is to be considered highly as he has the experience to back up his views.
    For a E-Bay 32" Cat or a Hand crafted derivative I will go with XL cans.
    8XL's on 4S via 100A speedies, to 440 props..........Then prop up. !!
    • ozzie-crawl
      • Sep 2008
      • 2943
      thanks simon, i do agree with you on these cats being between a l-xl a l is just not enough tho i would like to see a ul-1 motor run in one as they are a 6 pole motor so should deliver more torque. if you are going to run 2 8xls i would advise to add some carbon fibre over the tunnel and sponsons. on my single cat iam thinking of changing to a 8xl as the 7xl is a bit hot, not that the amp draw or temps are a problem just with a top speed between 55-60mph when it comes undone its taking a toll on the hull, i have it in pieces at the moment just adding carbonfibre and beefing up the drive line.
      scott
      • Simon.O.
        • Oct 2007
        • 1611
        Scott, a the risk of this thread going off topic I'll say that extra carbon will not be needed when I do a Twin Cat.
        I will design and build the hull to take the power that 8XL's can push.
        I just need to finish and run the Rigger then it is Twin-Cat time !!!
        • ozzie-crawl
          • Sep 2008
          • 2943
          was thinking off the agitator copy as i have had trouble with mine cracking in the sponsons
          • lomdel
            • 722
            I still need a source for a short standoff centre-mounted rudder with a push/pull servo-arm on both sides. It doesn't need to have a water-intake. About 120mm length below bracket...
            Something like the MHZ one below, but smaller and cheaper.
            • lomdel
              • 722
              Edited post above
