Andy & Paddy
  • andym
    More Go Than Show Prop Co
    • 2454
    #91
    Chuck if the rudder is on the left of the tub then I like mine angled out a deg or two. This helps with a couple of things, the slight out angle helps create a bit of lift and assist's the rear from dropping and then a flip, it also creates slight downward pressure on the inside sponson in a turn to help stop it lifting and the turn fin blowing out. Made a big difference to my old xs2.
    • egneg
      • 4759
      #92
      Andy the rudder is mounted on the right - this is how I got it. So I have several constraints as I did not build this boat but will do my best to make it work. I may end up having to take everything out and start over as the wire drive is set at a shallow angle as well. I can't get the strut to 20mm without quite a positive angle in order to keep the wire from hitting the strut.
      IMPBA 20481S D-12
      • egneg
        • 4759
        #93
        I have the XS2 almost ready to go! I need some tubing for the water cooling and it will be off to the pond. I will go to the LHS in a bit and hopefully will have it wet later this afternoon. I thank everyone for their advice and help.
        Chuck
        IMPBA 20481S D-12
        • Flying Scotsman
          Fast Electric Adict!
          • 5195
          #94
          Chuck, that is a great build. For some of you young Turks
          Douggie
          • Xzessperated
            • Apr 2008
            • 3063
            #95
            Douggie
            The fun is about to start. I am looking forward to your "on water" report. Take a gps with you Chuck as you are about to set your personal best speed.
            • egneg
              • 4759
              #96
              I will Paddy - but I think I will run it a bit first so it doesn't join my first one at the bottom of the pond
              IMPBA 20481S D-12
              • egneg
                • 4759
                #97
                Except for the great picture things went downhill. The back end hopped so bad that it never really hooked up. I brought it in and made some adjustments but forgot to tighten the coupler and it went nowhere fast. When I got it back it had taken on about an 1/8 cup of water and I couldn't get the ESC to arm. So I called it a day and am now drying things out so I can find the source of the leak.
                Edit: I do have to say that I am very impressed with the wire drive as I can't think of a harder test for it considering that it went from no load to full load repeatedly in a very short span of time.
                IMPBA 20481S D-12
                • Xzessperated
                  • Apr 2008
                  • 3063
                  #98
                  Chuck,
                  What prop were you running? I have only ever got a V series prop to hook up one time. It went like a cut cat when it did and registered 75mph. All the other times I have tried to use a V series prop I get the same hop.
                  The angle of the strut will cause the hop also. It has to be level. I am sure Andy will throw you a life buoy also.
                  • tth
                    • Apr 2008
                    • 1600
                    #99
                    Not to butt in, I also have mixed results with the V- series. I know all about the hop. What Paddy says is true, when these props catch you better have some good underpants on.
                    • egneg
                      • 4759
                      #100
                      I was running a Prather 215 so I am sure it was improper strut setting.
                      IMPBA 20481S D-12
                      • egneg
                        • 4759
                        #101
                        Good news and bad news. The good news is ESC is just fine because as I suspected the connection on the extension is what got wet and why the esc wouldn't arm. The bad news isn't really that bad as I found the source of the leak. I feel like an idiot because I didn't see it before I put the boat in the water. There is a hole for the antenna wire just below the bracket and I am using a tactic Tx/Rx. I will remove the bracket and fill the holes before the next test run.
                        IMPBA 20481S D-12
                        • andym
                          • 2454
                          #102
                          Just use some RTV Silicone where the wire goes through, cup that prop a little and set your strut neutral. All will be good. Nice work
                          • Flying Scotsman
                            • 5195
                            #103
                            Wait till he gets his new motor.
                            Douggie
                            • egneg
                              • 4759
                              #104
                              Douggie
                              Douggie The motor arrived today safe and sound and looks great. I have bench tested it and everything works just fine.
                              IMPBA 20481S D-12
                              • Xzessperated
                                • Apr 2008
                                • 3063
                                #105
                                I hope the paint never got scratched in transit.
