Offshore Electrics is now Offshore Electrics Inc.
  • Ub Hauled
    • 3051
    1/4 flex with step down to 3/16
    1/4 bullet nut
    • Steven Vaccaro
      Administrator
      • 8932
      Originally posted by AntronX View Post
      1/4" flex shafts, struts, motor couplers
      * I have those items now. hughey 1/4, speedmaster 1/4 stinger, octura 1/4 couplers.
      8 AWG silicon fine strand wire
      * I've been searching for 8 gauge silicon, but havent found it.
      big controllers (Schulze 40/160)
      *working on it.
      5" rail motor mounts for Neu 2230, 2215
      *ok
      water cooling for 2230
      * I have only been able to get 1 of these motors out of Neu in 6 months. Its on the board, but at the bottom.
      rudders for 44" - 50" boats
      Got them now, speedmaster.
      finished props in 55 - 62 mm range
      *Finished props are slow at best. Email me and I can forward you to a good balancer.
      big chargers (iCharger 1010B+)
      *maybe
      big servos
      *ok, whats the better ones out there?
      Futaba FASST radios
      *na, I'm a Hitec man
      MG Chemicals silicone conformal coating
      *dp-270 kicks the crap out of the scray, the spray is for lazy people. lol
      Steven Vaccaro
      • jcald2000
        • 786
        But it also holds the heat in.
          • 7512
          Originally posted by D.Smock View Post
          Congratulations Steven!!
          I'd be happy to sit on the board.
          Doug
          Steve will have to make sure that "board" has a rusty nail in it.
          • Steven Vaccaro
            Administrator
            • 8932
            Only if you use a ton of it, the spray will NOT totally protect your esc or rx. I've done actual dunk tests. Esc's and rx's will run while under water with an epoxy coating, they will not reliably with the spray. But I agree that if you are worried about heat, use the spray. Just dont count on it being water proof, just water resistant.
            Steven Vaccaro
            • Steven Vaccaro
              Administrator
              • 8932
              lol
              Steven Vaccaro
              • AntronX
                • 361
                I don't like spray either. I bought one quart of this stuff in a jug. It is useful for dipping ends of LiPos to waterproof them. I brushed it on my receiver board and it went diving couple of times. This coating can be easily removed with acetone and a tooth brush. It's also flexible and allows circuit boards and components to expand without cracking.
                The reason epoxy worked better on your receiver could have been due to frequency your RX is made for. If it's 75 Mhz or 27 Mhz, then having extra thick insulation kept water further away from tuned circuits on your RX. This helped to prevent de-tuning of your receiver due to water's conductivity. On my 2400 Mhz RX, tuned circuits are so small that thin silicone coating is enough.
                Also, I would like to add EagleTree boat wireless logger with 300A current sensor to my items wanted list i posted earlier. I found that V3 logger even with 150A option is not big enough to use in large electrics.
                • DISAR
                  • 1137
                  How about this one from Medusa Research? 200A also available with wires intead of Deans. Looks like the eagle tree but at 200A. Any experience?
                  115$ for the complete package
                  1 Oracle Data Recorder (MR-DR-60100 or MR-DR-60200)
                  1 Temp Sensor (MR-TEMP-001)
                  1 RPM Phase Sensor (MR-RPM-002)
                  1 POWERLink USB Adapter (MR-USB-001)
                  w/USB Cable
                  IKAN88 dengan mudah menyesuaikan strategi di setiap permainan—kadang agresif kayak hiu, kadang sabar kayak ikan mas.
                  http://www.rcfastboats.com/
                  • sailr
                    • 7128
                    I would 2nd the idea of NEU batts. They have some new ones you can charge at 5C. PolyRC's are good but too expensive and I HATE the way they treat the balance wiring as well as the Thunderpower tiny balance plug.
                    Mini Cat Racing USA
                    www.minicatracingusa.com
                    • Doozie870
                      • 970
                      My vote, Zippy Rhino's
                      • sailr
                        • 7128
                        Zippy Rhino's! Ouch. I'll pass! We want to keep Steven in business! Just order those direct from Hobby City!
                        Mini Cat Racing USA
                        • DISAR
                          • 1137
                          Hobby city is doing very wel I think. All the zippys they bring (500-700?) they are all gone within a month or less. This is from what I see on their site.
