what esc
  • avengersteve
    • 395
    what esc
    im doing a special build that i will reveal later, im using the stock sv27 motor, and am need of an esc capible of reverse. i would like for the esc to be able to hadle at leat 8 cells so i can keep the power to the motor high for speed reasons. any sugestions.
    restoring the collection
  • Darin Jordan
    • 9446
    A Barracuda 80 can be set-up with reverse active, and would be plenty of ESC for your application...
    Darin E. Jordan - Renton, WA
    • Doug Smock
      • 5359
      Be careful if your going to use a cable.
      Doug
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
      • Darin Jordan
        • 9446
        Doug
        VERY good point... Cable is directional... On the Castle controllers, you can set the percentage of throttle that reverse can be... 12.5%, etc... I'd set it to a low setting since it's only for dinking around... Otherwise, you may unwind your cable and cause yourself a mess...
        • avengersteve
          • 395
          yeah i was thinking about that.. i was going to keep reverse at ex treemly low power
          • part time
            • 154
            if u cant find an esc to do it just set the epa on the tx to 12%
